Yes same problem when removing quotes
epics> dbLoadRecords("db/arduino.db","PORT=SERIALPORT")
epics> iocInit()
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Oct 24 2019
2019/11/07 16:04:56.709466 _main_ Cannot find a bus named 'SERIALPORT' for 'aoa'
2019/11/07 16:04:56.709716 _main_ aoa: Can't attach to bus SERIALPORT -1
2019/11/07 16:04:56.709783 _main_ aoa: Record initialization failed
Thad
Sent: Thursday, November 07, 2019 10:40 AM
To: Seeberger, John T CIV USN NAS PAX MD (USA)
Cc: [email protected]
Subject: [Non-DoD Source] Re: Serial port bus connection issue on arm platform
Hi John,
Inside your dbLoadRecords second argument, try removing the single quote characters from around the word ‘SERIALPORT’.
- Andrew
Sent from my iPad
> On Nov 7, 2019, at 8:55 AM, Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk <[email protected]> wrote:
> Good day. I have a database with 7 PV's that drive an aviation six pack. I have successfully built and run on Xilinx ultrascale dev board, Epics base-3.15.5, synApps_6_0 compiled with aarch64. The ioc runs fine under petalinux on zcu106. The simulator uses /dev/ttyUSB0 to talk to a labview application that feeds the data. The example is based upon an arduino example I found on the web. Very simple.
> Now I want to target gnueabihf Xilinx zynq 7000 and run on zc706 and NAII board. Database unchanged. I recompiled epics base and syncapps with 32 bit arm compiler, rebuild petalinux. Now when I run I'm getting errors with the serial port. Here is what I think are relevant snippits.
> The aoa record:
> record(ai, aoa) {
> field(DESC, "Angle of Atack Sensor")
> field(DTYP, "stream")
> field(INP, "@aoa.proto get_analog() $(PORT)")
> field(SCAN, ".1 second")
> field(HOPR, "360")
> field(LOPR, "0")
> field(PREC, "2")
> field(FLNK, "speed")
> I limit the error message to first PV, but all records have same errors.
> The serial port is there, functional, permissions fine. The same database and startup works fine when built with aarch64 compiler and run on zcu106.
> I would like to get working under the 32 bit arm zynq, so the database run on a North Atlantic Industries VPX, or VME board.
> Startup:
> epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db")
> dbLoadDatabase("dbd/helloWorldIOC.dbd")
> helloWorldIOC_registerRecordDeviceDriver(pdbbase)
> drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyUSB0",0,0,0)
> asynSetOption("SERIALPORT",-1,"baud","115200")
> asynSetOption("SERIALPORT",-1,"bits","8")
> asynSetOption("SERIALPORT",-1,"parity","none")
> asynSetOption("SERIALPORT",-1,"stop","1")
> asynSetOption("SERIALPORT",-1,"clocal","Y")
> asynSetOption("SERIALPORT",-1,"crtscts","N")
> dbLoadRecords("db/arduino.db","PORT='SERIALPORT'"
> iocInit()
> Starting iocInit
> ## EPICS R3.15.5
> 2019/10/31 21:26:01.810631 _main_ Cannot find a bus named 'SERIALPORT' for 'aoa'
> 2019/10/31 21:26:01.810770 _main_ aoa: Can't attach to bus SERIALPORT -1
> 2019/10/31 21:26:01.810834 _main_ aoa: Record initialization failed
> Warning: RSRV has empty beacon address list
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq snchelloWorldIOC,"user=johnseebergerlin"
> 2019/10/31 21:26:02.413981 scan-0.1 aoa: Record not initialised correctly
> dbior
> Driver: stream
> StreamDevice 2.7.7 built Oct 24 2019 13:43:29
> registered bus interfaces:
> DebugInterface
> DummyInterface
> Driver: drvAsyn
> SERIALPORT multiDevice:No canBlock:Yes autoConnect:Yes
> Serial line /dev/ttyUSB0: Connected
> dbior "stream"
> Driver: stream
> DebugInterface
> DummyInterface
> found this relevant tech-talk post:
> If AsynDriverInterface is not listed, have you accidentally commented out the bus interface in CONFIG_STREAM?
> Unfortunately, with asyn 4-5, you still have to specify ASYN_VERS=4-3 in
> CONFIG_STREAM (I will fix that later).
> What is this refering to, where is this?
> How can I further debug?
> thx
> Thad
- Re: Serial port bus connection issue on arm platform Kasemir, Kay via Tech-talk
- Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
- Re: Serial port bus connection issue on arm platform Johnson, Andrew N. via Tech-talk
Re: rmt CCExecInit problem Michael Davidsaver via Tech-talk
Connection Timeout Using Asyn and StreamDevice with Ethernet Device Kyle Hesse via Tech-talk
<2019>
<2019>
