Subject: |
../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory |
Valentyn Stadnytskyi via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Sun, 17 Nov 2019 14:06:54 -0600 |
Hello,
I am having problem running a test IOC I just created following instructions https://epics-controls.org/resources-and-support/documents/getting-started/:~/EPICS/epics-base/test/testIoc/iocBoot/ioctestIoc$ ./st.cmd -bash: ./st.cmd: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Back in 2016 Daniel Crisp had a similar error. https://epics.anl.gov/tech-talk/2016/msg01736.php../../bin/linux-x86_64/<PROD_IOC>^M: bad interpreter: No such file or directory
He had an extra symbol at the end resulting in a conflict. In my case it seems to be fine but I get the same error. I have looked into /bin/ folder and I cannot find linux-x86_64 there. (I tried to use find and ls -a)
The st.cmd file looks fine except the first line that presumably points at non-existing directory. #!../../bin/linux-x86_64/testIOC
#- You may have to change testIOC to something else #- everywhere it appears in this file
< envPaths cd "${TOP}"
## Register all support components dbLoadDatabase "dbd/testIOC.dbd" testIOC_registerRecordDeviceDriver pdbbase
## Load record instances dbLoadTemplate "db/user.substitutions" dbLoadRecords "db/testIOCVersion.db", "user=femtoland" dbLoadRecords "db/dbSubExample.db", "user=femtoland"
#- Set this to see messages from mySub #var mySubDebug 1
#- Run this to trace the stages of iocInit traceIocInit
cd "${TOP}/iocBoot/${IOC}" iocInit
## Start any sequence programs #seq sncExample, "user=femtoland"
And my envPath entries are pointing to where I think they should point. I didn’t change anything, it was all generated automatically, but I still inspected it. epicsEnvSet("IOC","ioctestIoc") epicsEnvSet("TOP","/home/femtoland/EPICS/epics-base/test/testIoc") epicsEnvSet("EPICS_BASE","/home/femtoland/EPICS/epics-base")
Do I need to install some extra module or is something missing on my Linux installation? I am running Ubuntu 18.04
Thank you! Valentyn
- Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Michael Davidsaver via Tech-talk
Re: Getting started with EPICS Heinz Junkes via Tech-talk
string conversion to uppercase or lowercase Jeong Han Lee via Tech-talk
<2019>
2025
<2019>
2025
ANJ, 17 Nov 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
