1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: P4P release 3.4.1, now with gateway
From: Michael Davidsaver via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 10 Dec 2019 08:22:34 -0800
P4P 3.4.1 is available on github.com[1] and pypi.org[2].  In addition to the usual fixes,
this release is the first to include a PVAccess gateway (aka. proxy).  This is installed
as the "pvagw" executable by both epics module and setuptools builds.
Documentation[3] is available.
The feature highlights are configurable access control (aka access security) including
the use of "roles" (aka. *NIX group names) in addition to user names.  Also logging of
Put operations.  A number of gateway status PVs are added, including accounting of network
bandwidth used by clients/servers/PVs.
This PVA gateway is intended to replace the prototype gateway from the pva2pva module.
Both use a similar JSON based configuration file.  Config files for the prototype should
work with this new gateway.
Thanks to SLAC for sponsoring this work, and to Bruce Hill specifically for his stress testing.
[1] https://github.com/mdavidsaver/p4p/releases/tag/3.4.1
[2] https://pypi.org/project/p4p/
[3] https://mdavidsaver.github.io/p4p/gw.html
[4] https://github.com/epics-base/pva2pva
Re: P4P release 3.4.1, now with gateway Michael Davidsaver via Tech-talk
Prev: RE: Custom asyn input EOS Hudson, Lee (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: P4P release 3.4.1, now with gateway Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pco Camera USB and IEEE interface Bradnick, Ben (Tessella, RAL, TEC) via Tech-talk
ANJ, 11 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
