1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Old base version bug in configure/os/CONFIG_SITE.linux-x86_64.UnixCommon
Cc: [email protected]
Date: Wed, 11 Dec 2019 14:42:24 +0900
Hi Mark,
Did you mean 3.14.12.3 instead?
Sorry for my typo... It is 3.14.12.3.
  Why are you trying to run 3.14.12..3 which is 8 years old, rather than the latest bug-fix release that is only 1 year old?
Actually our operation environment (in KEK Linac) is still using base 3.14.12.1 or 3.14.12.4. These releases are OK when TARGET_ARCHS is vxworks. But I want to test some software so I installed several base versions and set TARGET_ARCHS as linux and found this bug.
Di WANG
On 2019-12-11 13:48, Mark Rivers wrote:
  I tried to install an old version EPICS base 3.12.14.3
There is no such release.  Did you mean 3.14.12.3 instead?  That is from 2011.
  So I am wondering if anyone intended to fix this error in these old versions,
These are "releases" and by definition cannot be fixed.
3.14.12.x, where x=2-8 are bug fix releases, which only fix bugs and do not break the API.  Why are you trying to run 3.14.12..3 which is 8 years old, rather than the latest bug-fix release that is only 1 year old?
From: Tech-talk <[email protected]> on behalf of Di Wang via Tech-talk <[email protected]>
Sent: Tuesday, December 10, 2019 8:39 PM
To: [email protected]
Subject: Old base version bug in configure/os/CONFIG_SITE.linux-x86_64.UnixCommon
     I tried to install an old version EPICS base 3.12.14.3 on CentOS and downloaded the source file from the ANL site:
     https://epics.anl.gov/download/base/index.php
     and found an error (an extra '$' character) in the "configure/os/CONFIG_SITE.linux-x86_64.UnixCommon" file.
     I searched on the tech talk and checked the git history and as Andrew Johnson said in this thread:
      https://epics.anl.gov/tech-talk/2016/msg02163.php
     This error happened since 2005 and affected many old versions. Finally it was removed by Andrew Johnson at 2016 after base 3.14.12.6.  So I am wondering if anyone intended to fix this error in these old versions, or if not, maybe add some "README.FIRST" on the download website?
Di WANG (Linac, KEK)
<https://epics.anl.gov/tech-talk/2016/msg02163.php>
Old base version bug in configure/os/CONFIG_SITE.linux-x86_64.UnixCommon Di Wang via Tech-talk
Re: Old base version bug in configure/os/CONFIG_SITE.linux-x86_64.UnixCommon Mark Rivers via Tech-talk
Prev: Re: Old base version bug in configure/os/CONFIG_SITE.linux-x86_64.UnixCommon Mark Rivers via Tech-talk
Next: Re: Record for a running sum Donny Domagoj Cosic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: ignoring the string that was not asked for in streamdevice protocol Hinko Kocevar via Tech-talk
ANJ, 11 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
