1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re:RE: help for streamDevice question
To: "Mark Rivers" <[email protected]>
Date: Mon, 6 Jan 2020 11:43:39 +0800 (CST)
Sorry.
I want to send many socket packages to  a device.
A single package consist of a 8 bytes time stamp(changeable), a 4 bytes protocol number, a 4 bytes determined number and a 8 bytes check code(changeable).
Time Stamp
Protocol
Vision
Command
Check Code
8 bytes
4 bytes
4 bytes
8 bytes
What I suppose is to use hex format to save the data.
So I write record like this:
record(waveform,"data")
field (DTVP, "stream")
field(INP, "@devTest.proto array_in L0")
field(FTVL, "LONG")
field(NELM, "256")
field(PINI, "YES")
field(SCAN, "Passive")
and proto file
data0 = 0x23;
array_in {
out "\${data0}";
in "%4x";
In this case, only determined data can be sent. I hope to sent some changeable data which produced by a python program in real-time.
Thank you very much.
YaweiZhang
At 2020-01-06 00:22:42, "Mark Rivers" <[email protected]> wrote:
I think you need to be more specific.  What is the format of the strings you are trying to write and read?
From: Tech-talk <[email protected]> On Behalf Of ??? via Tech-talk
Sent: Sunday, January 5, 2020 8:22 AM
To: [email protected]
Subject: help for streamDevice question
hi
    I want to use streamDevice to communicate with a device just like  https://epics.anl.gov/tech-talk/2016/msg01310.php does.
    My problem is that I don't know how to write changeable data into record, which include  time and a time-dependent encryption number.
    Could someone give me a hand?
    Thanks a lot.
YaweiZhang
Re: Re:RE: help for streamDevice question Mark Rivers via Tech-talk
help for streamDevice question 张亚威 via Tech-talk
Prev: Re: Ethernet question Mark Rivers via Tech-talk
Next: Re: Ethernet question Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: RE: help for streamDevice question Mark Rivers via Tech-talk
Next: Re: Re:RE: help for streamDevice question Mark Rivers via Tech-talk
ANJ, 06 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
