1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Finding the PV for a specific device?
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 6 Jan 2020 21:26:00 +0000
Hi Emma,
This is a thoroughly solved problem, and the solution is available on github.  I'm going to suggest using an overly general solution and cutting it down to what you need, instead of a specific solution to this narrowly defined problem, because there is more help available (in the form of scripts, etc.) for the general solution.
I would install synApps (EPICS support for many of the things people do at synchrotron-radiation beamlines) on a Linux workstation by downloading the following script:
It's possible to install and build on a Windows machine, but I'm not the person who can tell you how to do that.
Edit assemble_synApps.sh to specify the path to a copy of EPICS base that is built for Linux.
Find, in assemble_synApps.sh a list of module names and versions, which begins with
    ALLENBRADLEY=2.3
    ALIVE=R1-1-1
Comment out all such lines except ASYN, AUTOSAVE,  MOTOR, and XXX, and run it:
% bash assemble_synApps.sh
This goes out on the web and finds the modules, downloads them, and configures them into a system.
Then tailor the modules to what you need:
% cd synApps/support
edit asyn-Rx-xx/configure/RELEASE to comment out the definition of IPAC
edit motor-Rx-xx/configure/RELEASE to comment out BUSY, and IPAC
edit motor-Rx-xx/modules/Makefile to comment out all SUBMODULE definitions except "SUBMODULES += motorAerotech"
edit xxx-Rx-xx/xxxApp/src/Makefile, find "ifdef MOTOR", and comment out all
"$(DBD_NAME)_DBD +=" definitions in that section, then add this line:
$(DBD_NAME)_DBD += motorSupport.dbd devAerotech.dbd
Also comment out all "$(PROD_NAME)_LIBS := " definitions, and add this line:
$(PROD_NAME)_LIBS := motor Aerotech $($(PROD_NAME)_LIBS)
Then build the modules (still in the synApps/support directory):
% setenv EPICS_HOST_ARCH linux-x86_64 (or whatever arch EPICS base was built for)
% make >&make.out
If the build succeeds, it will give you an ioc directory, which you must customize:
% cd xxx-Rx-xx/iocBoot/iocxxx
Edit st.cmd.Linux to comment out the lines
    < common.iocsh
and
    dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db","IOC=xxx")
Add the following lines (before IocInit):
    # Substitute the IP address of your Ensemble controller in the following line
    drvAsynIPPortConfigure("tcp1","164.54.113.74:8000", 0, 0, 0)
    EnsembleAsynSetup(1)
    EnsembleAsynConfig(0, "tcp1", 0, 1, 100, 1000)
    drvAsynMotorConfigure("AeroE1","motorEnsemble",0,1)
    dbLoadTemplate("AsynMotor.substitutions")
Make the file AsynMotor.substitutions, with the following content:
<--snip-->
file "$(MOTOR)/db/asyn_motor.db"
pattern
{P,       N,        M,          DTYP,    PORT, ADDR,          DESC,  EGU,   DIR, VELO,  VBAS,  ACCL, BDST,  BVEL,  BACC,            MRES, PREC,  DHLM,  DLLM,  INIT}
{xxx:, 100,   "m$(N)",  "asynMotor",  AeroE1,    0,  "motor $(N)",  deg,   Pos,    1,     0,   0.2,    0,     1,   0.2,            5E-5,    5,     0,     0,    ""}
<--snip-->
Now type
% ../../bin/${EPICS_HOST_ARCH}/xxx st.cmd.Linux
This should run the IOC, and make PVs for the motor.  The PV xxx:m1.VAL should drive the motor, and xxx:m1.RBV should tell you its current position.  The best way to test out a motor is to run a display manager, such as caQtDM, and bring up the motor's GUI display.  If you have caQtDM, do this:
% start_caQtDM_xxx
Click on "Motors 1-8", click on "m1" and choose "m1 (Debug)"
If I recall correctly, you have to turn torque on.  You may also have to home the motor.
In any list this long, there are likely many things that will go wrong.  If this seems like an approach you're willing to undertake, go for it and come back with problems as they arise.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Emma-Elizabeth Cating-Subramanian via Tech-talk <[email protected]>
Sent: Monday, January 6, 2020 11:18 AM
To: [email protected] <[email protected]>
Subject: Finding the PV for a specific device?
Hello,
I'm just starting to use EPICS and am running into a bit of an issue. I've got an Aerotech Ensemble stage connected to my computer via ethernet. I want to be able to interface with it through EPICS. How do I find out what the PV is that I need to give to EPICS? Does EPICS just search for ethernet devices and assign PVs? If so, how do I retrieve that information?
I've asked this question of a few people now and no one has been able to give me a useful answer, so perhaps I have been phrasing it incorrectly. Maybe a better way is, if you connected a new Aerotech stage to your computer, could you walk me through the steps you would take to make it move using EPICS?
Emma Cating-Subramanian
Postdoctoral Researcher
Kapteyn-Murnane group
JILA
CU Boulder
Re: Finding the PV for a specific device? Mooney, Tim M. via Tech-talk
Finding the PV for a specific device? Emma-Elizabeth Cating-Subramanian via Tech-talk
Prev: Re: EPICS R3.15 and menuScan.dbd Johnson, Andrew N. via Tech-talk
Next: Re: EPICS R3.15 and menuScan.dbd Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Finding the PV for a specific device? Emma-Elizabeth Cating-Subramanian via Tech-talk
Next: Re: Finding the PV for a specific device? Mooney, Tim M. via Tech-talk
ANJ, 06 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
