Subject: Re: Question about two minor issues with IOCs
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Date: Thu, 16 Jan 2020 19:21:19 +0000
Increasing to 2500 would solve it for your specific IOC, but if you then decide to load 20 ROI plugins rather than 5 that might not be enough.
A better solution is to add callbackSetQueueSize(5000) to ADCore/iocBoot/EXAMPLE_commonPlugins.cmd.
I think that this is in fact a better solution. That way when adding plugins this number can be adjusted if necessary. I ran the dbnr command in my IOC and
I got the following:
epics> dbnr
Records  Aliases  Record Type
     2        1    sub
   777        0    longout
   312        0    mbbi
  2296        0    longin
   880        0    subArray
   138        0    stringout
    34        0    dfanout
   662        1    ai
   304        0    calcout
   542        0    waveform
     2        0    fanout
   182        0    calc
    78        0    busy
   466        0    bo
     7        0    seq
   421        0    bi
   431        0    ao
    17        0    sseq
   232        0    mbbo
    44        0    asyn
   601        0    stringin
Total 8428 records, 2 aliases
Meaning that I have several hundred more records due to the additional plugins, which is why I get the message on every IOC startup.
Thanks for helping explain this issue,
Jakub
Sent: Thursday, January 16, 2020 2:03 PM
To: Wlodek, Jakub <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: Question about two minor issues with IOCs
Ø  Is there a reason we shouldn't slightly increase the queue size in base to avoid this? Even around 2500 for example should solve this issue.
I think 2000 was chosen to keep memory footprint low for RTEMS and vxWorks, while being large enough that overflows are rare in most IOCs.
A better solution is to add callbackSetQueueSize(5000) to ADCore/iocBoot/EXAMPLE_commonPlugins.cmd.  I will do that.
That will work with any version of base, and could be modified by the site or specific IOC.
This is the number of records of each type in a standard simDetector IOC that loads commonPlugins.cmd.
epics> dbnr
    18        0    sseq
   272        0    calcout
     9        0    seq
   138        0    stringout
   428        0    bo
    34        0    dfanout
   279        0    mbbi
    67        0    busy
   208        0    mbbo
   379        0    ao
    39        0    asyn
   496        0    waveform
     3        0    fanout
  2073        0    longin
   370        0    bi
   780        0    subArray
   162        0    calc
   732        0    longout
     4        0    scalcout
     2        1    sub
   587        1    ai
   519        0    stringin
     5        0    sscan
Total 7604 records, 2 aliases
The input records are the ai, bi, mbbi, longin, stringin and some of the waveform records.  Most of these have SCAN=I/O Intr and so do callbacks at iocInit.  This is nearly 3900 records, which is why 2000 is sometimes not a large enough queue.  It depends on the speed at which the records can process compared to the rate at which the asynPortDrivers do callbacks at iocInit.  A queue size of 5000 seems like it should be enough.
Sent: Thursday, January 16, 2020 12:33 PM
Hi Mark,
I ran the callbackQueueShow command, and it does seem that the callbacks overflow by a little bit:
epics> callbackQueueShow
PRIORITY  HIGH-WATER MARK  ITEMS IN Q  Q SIZE  % USED  Q OVERFLOWS
   cbLow             2000           0    2000     0.0           64
cbMedium                0           0    2000     0.0            0
  cbHigh                0           0    2000     0.0            0
Meaning that the additional plugins are most likely the cause of this error message.
I can add the callbackSetQueueSize(5000), and the messages go away. Is there a reason we shouldn't slightly increase the
Jakub
Sent: Thursday, January 16, 2020 1:18 PM
Ø  In my case, I see at least a few printings of that error on every IOC boot,
Ø  though this may be because I have several additional plugins loading
Ø  PVs at startup, which means that I have more PVs than the example IOCs, however,
Ø  I had the same amount of plugins loading without this error on earlier releases.
I just typed the callbackQueueShow command on my simDetector IOC.  I see the following:\
   cbLow             1875           0    2000     0.0            0
Note that I did not overflow the queue, but it was close, 1875/2000.  I started the IOC 4 times and that high-water mark varied from 1580 to 1930.  So sometimes it will probably be over 2000.
What do you see?
You can probably eliminate the overflows by adding the following command to your startup script before iocInit()
Sent: Thursday, January 16, 2020 12:03 PM
Hi Mark,
I am currently running the following versions of all modules:
ADCore - R3-8
base - R7.0.3.1
asyn - R4-37
I have also seen this buffer full error with ADCore R3-7 IOCs, though I don't remember seeing it on any earlier versions, and I don't remember
which base/asyn those were running.
In my case, I see at least a few printings of that error on every IOC boot, though this may be because I have several additional plugins loading
PVs at startup, which means that I have more PVs than the example IOCs, however, I had the same amount of plugins loading without this error on earlier
releases.
The other error also happens every IOC boot, but that one I haven't seen until recently, although it is possible it simply went unnoticed by me
in earlier versions.
Jakub
Sent: Thursday, January 16, 2020 12:40 PM
Hi Jakub,
I have been seeing both of those messages on my areaDetector IOCs as well.
Ø  Error (511,511) PV: 13SIM1::TIMEZONE devStringinEnvVar (init_record) Illegal INP parm field
That message happens every time the IOC boots for me.  I have been assuming is a problem with devIocStats, and have been meaning to track it down.
Ø  callbackRequest: cbLow ring buffer full
That message only very occasionally happens for me at the end of iocInit.  I believe it happens when the number and rate of driver callbacks for PVs are too large, so that the queue in EPICS base overflows.  We could probably eliminate them by increasing the size of that queue.  But before doing that I want to know why they just started happening, and I did not see them before.
I am running base 7.0.3.1 and the master branch of asyn.  The question is whether it was a change in either of those that caused the messages to start happening.
Note that this error can actually be serious, because it means that some records will not have their correct values, because the callback events were missed.
Do you see those cbLow messages every time you boot?  What version of base,  asyn and ADCore are you using?
From: Tech-talk <[email protected]> On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Thursday, January 16, 2020 9:53 AM
To: [email protected]
Subject: Question about two minor issues with IOCs
Hi all,
I have been working on setting up some new USB cameras at a beamline recently, and I noticed two errors showing up in the IOC
shell, though the IOCs for the cameras actually work fine after startup. I wanted to ask if anyone knows why these show up, and how
to resolve them. To make sure it wasn't specific to the driver I had written, I compiled ADSimDetector against the same base, asyn etc,
and I still saw them showing up:
The first seems to be an issue with autosave, as this shows up right after reboot_restore starts:
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
The second issue happens after the auto_settings.req file is loaded:
create_monitor_set("auto_settings.req", 30, "P=13SIM1:")
And is buffer full message is repeated ~30 times.
After all of these messages, I get a message that all the PVs are connected, and the IOC runs with no issues, which is puzzling to me.
If anyone could give me some advice on the source and solution to these that would be great.
Jakub Wlodek
RE: Question about two minor issues with IOCs Mark Rivers via Tech-talk
Question about two minor issues with IOCs Wlodek, Jakub via Tech-talk
Re: Question about two minor issues with IOCs Wlodek, Jakub via Tech-talk
Prev: RE: Question about two minor issues with IOCs Mark Rivers via Tech-talk
Next: Re: EDM website and status J. Lewis Muir via Tech-talk
Next: RE: Question about two minor issues with IOCs Mark Rivers via Tech-talk
