Subject: RE: Arithmetic calculations before sending a command
To: 'dmnr infn' <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 20 Jan 2020 17:23:10 +0000
Ø  but when the user want send a value like 100 I want to send 10 to the device. How can I do this calculation before sending the value?
Ø  I tried SET VOLT (%.0f/10) but it doesn't work.
Look at the documentation here: https://paulscherrerinstitute.github.io/StreamDevice/ao.html
For output formats using %f on the ao record you can use the ASLO and AOFF fields to scale the OVAL field.
From: Tech-talk <[email protected]> On Behalf Of dmnr infn via Tech-talk
Sent: Monday, January 20, 2020 10:48 AM
To: [email protected]; [email protected]
Subject: Arithmetic calculations before sending a command
Hi everyone,
I have a DB with protocol in this manner:
record (ao, "RF:Setth_a0")
    field (DESC, "Setting threshold accelerator")
    field (DTYP, "stream")
    field (OUT,  "@MDO.proto setth_a0 $(PORT)")
    field (DRVL, "0")
    field (DRVH, "11230")
    field (LOPR, "0")
    field (HOPR, "11230")
    field (PREC, "0")
setth_a0 {
    out "SET VOLT %.0f";
With CS Studio I have a spinner associated to this PV, but when the user want send a value like 100 I want to send 10 to the device. How can I do this calculation before sending the value?
Thank you.
Arithmetic calculations before sending a command dmnr infn via Tech-talk
Prev: Arithmetic calculations before sending a command dmnr infn via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Next: Spring Meeting? Patrick Oppermann via Tech-talk
