Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Tech-talk <[email protected]>
Date: Tue, 21 Jan 2020 09:24:30 +0100
Am Mon, 20 Jan 2020 07:18:23 +0100
schrieb Gerrit Kühn via Tech-talk <[email protected]>:
> > The scalcout record comes from the synApps "calc" module.  When you
> > build streamDevice your configure/RELEASE file needs to point to CALC
> > if you want to use that record.  The details vary between releases of
> > streamDevice.  When you build your application you also need to include
> > CALC if you enabled it when building streamDevice.
> That'll the the reason then. I have calc installed and built StreamDevice
> with it, but not the application. Still, it feels a bit strange that
> everything appears to continue to run after this error, just the path
> isn't set during initialisation.
Hm, I tried to fix this now by adding CALC to the application (both in the
configure/RELEASE and in the environment), but the record it creates is
still empty. No error messages to be seen during the build, though. What
do I have to check to find out where this is not being picked up properly?
cu
  Gerrit
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Ralph Lange via Tech-talk
StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Prev: RE: Arithmetic calculations before sending a command Mark Rivers via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Ralph Lange via Tech-talk
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
