Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
Date: Mon, 20 Jan 2020 07:18:23 +0100
Am Fri, 17 Jan 2020 14:12:53 +0000
schrieb Mark Rivers <[email protected]>:
> The scalcout record comes from the synApps "calc" module.  When you
> build streamDevice your configure/RELEASE file needs to point to CALC if
> you want to use that record.  The details vary between releases of
> streamDevice.  When you build your application you also need to include
> CALC if you enabled it when building streamDevice.
That'll the the reason then. I have calc installed and built StreamDevice
with it, but not the application. Still, it feels a bit strange that
everything appears to continue to run after this error, just the path
isn't set during initialisation.
cu
  Gerrit
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Prev: Re: Re: [EXTERNAL] Probelm with ethernet interface of Galil controller wangqisheng--- via Tech-talk
Next: AW: ca-gateway 2.1.2 compilation error Sintschuk, Michael via Tech-talk
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
