Subject: Re: Read/Write waveforms using Channel Access C API
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 23 Jan 2020 13:48:56 +0100
Just to make sure...
You are aware that there are a number of existing tools for reading and writing sets of PVs (PVTable in CS-Studio, MASAR, CASR, BURT and others) and you have found them not being solutions to your problem.
Cheers,
~Ralph
On Thu, 23 Jan 2020 at 12:28, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
Hi
I am working on a tool which reads a list of PVs (some of which are waveforms) and save those PVs values for later loading them. My problem is with the waveform record, is there a way to know the waveform’s size and read each element? The way I am reading PVs is structured where each DBR type (double, long, enum and string for now) has a struct like this:
typedef struct {
                chid channel;
                int status;
                struct dbr_ctrl_TYPE info;
                struct dbr_sts_TYPE data;
Best Regards,
Abdalla.
RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Prev: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Next: RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
