Hi
I am working on a tool which reads a list of PVs (some of which are waveforms) and save those PVs values for later loading them. My problem is with the waveform record, is there a way to know the waveform’s size and read each element? The
way I am reading PVs is structured where each DBR type (double, long, enum and string for now) has a struct like this:
typedef struct {
chid channel;
int status;
struct dbr_ctrl_TYPE info;
struct dbr_sts_TYPE data;
Best Regards,
Abdalla.
- Re: Read/Write waveforms using Channel Access C API Ralph Lange via Tech-talk
Re:Re: usage of Java Channel Access Client 吴煊 via Tech-talk
<2020>
2025
Re: EPICS support for PoE Injector Hub Gessner, Spencer J. via Tech-talk
<2020>
2025
ANJ, 23 Jan 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
