All,
I have a new 5 channel Quantum Xspress3 data readout unit which when taking multiple frames will start generating hdf5 related error messages at what seems like random (will acquire between a few or thousands of frames before generating errors). Once these
messages start they seem to continue until the IOC segfaults.
repeating pair of error messages on the IOC console:
HDF5-DIAG: Error detected in HDF5 (1.8.12) thread 0:
#000: ../../src/H5Dio.c line 231 in H5Dwrite(): can't prepare for writing data
#001: ../../src/H5Dio.c line 348 in H5D__pre_write(): file selection+offset not within extent
minor: Out of range
This IOC is a binary that comes with the detector.
I have contacted Quantum. I thought that while waiting to hear from them it would make sense to build an IOC from source. On github I see
epics-modules/xspress3
and
quantumdetectors/xspress3-epics forked from the above.
Any advice on which i should go with? Any suspicions regarding the hdf5 errors?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
- RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Re: EPICS support for PoE Injector Hub Konrad, Martin via Tech-talk
<2020>
Re: Read/Write waveforms using Channel Access C API Ralph Lange via Tech-talk
<2020>
ANJ, 23 Jan 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
