Subject: Re: Read/Write waveforms using Channel Access C API
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 23 Jan 2020 16:10:44 +0100
I see.
Using the dbr_value_ptr() macro (from db_access.h) on your DBR_* structure will get you a pointer to the array data.
HTH,
~Ralph
Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Re: Read/Write waveforms using Channel Access C API Ralph Lange via Tech-talk
RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Prev: Re: EPICS support for PoE Injector Hub Konrad, Martin via Tech-talk
Next: CAEN SY127 via RS232 Jan Glorius via Tech-talk
Prev: RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Next: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
