I swapped the R7.0.3 for R7.0.3.1, and rebuilt, and the error reappeared (the path still has R7-0-3 since I swapped it in place to ensure using the same sources for modules/drivers):
epicsEventTrigger: pthread_mutex_unlock failed: Invalid argument
epicsEventMustTriggerThread CAS-client (0x7f3144042b40) can't proceed, suspending.
Dumping a stack trace of thread 'CAS-client':
[ 0x556aabd70b73]: /epics/src-7-0-3/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(epicsStackTrace+0x73)
[ 0x556aabd615a5]: /epics/src-7-0-3/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(cantProceed+0xc5)
[ 0x556aabcea793]: /epics/src-7-0-3/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(db_close_events+0x33)
[ 0x556aabd120bf]: /epics/src-7-0-3/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(destroy_tcp_client+0x8f)
[ 0x556aabd12cdd]: /epics/src-7-0-3/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(camsgtask+0x13d)
[ 0x556aabd6bfa8]: /epics/src-7-0-3/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(start_routine+0xf8)
[ 0x7f325539c6db]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xdb)
[ 0x7f325413188f]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
Thread CAS-client (0x7f3144042b40) suspended
However, I copied these sources onto a different machine and recompiled and I couldn't reproduce the error (The first machine is ubuntu 18.04, the second is debian 9),
so I'm guessing this issue is most likely tied to something on my local machine. Below are the non 'ok' tests from
make runtests for base R7.0.3.1 on the ubuntu machine:
dbServerTest.t ............. 1/25 dbRegisterServer: Can't redefine 'one'.
dbRegisterServer: Bad server name 'bad name'
dbRegisterServer: Ignoring 'disabled', per environment
dbUnregisterServer: Servers still active!
dbUnregisterServer: 'toolate' not registered.
dbUnregisterServer: 'no-routines' has no stop() method.
In addition, the following tests showed some error message, but were seemingly re-run successfully:
iocshTest.t ................... 1/19 Command no_such_command not found.
iocsh Error: Break
Can't open no_such_file.cmd: No such file or directory
iocshTest.t ................... ok
chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
chfPluginTest.t ............ ok
netget.t ................ 1/3 **** The executable "caRepeater" couldn't be located
**** because of errno = "No such file or directory".
**** You may need to modify your PATH environment variable.
**** Unable to start "CA Repeater" process.
netget.t ................ ok
There were also several tests that listed json parsing errors.
Jakub
