Hi Mark
Is this error consistent or intermittent?
I observe it every time I start an IOC, but not immediately after startup, it shows up after some time with normal operation (acquire start/stop, enable/disable plugins etc.)
I can't seem to nail down a specific series of steps that leads to the error, but it seems consistent. I also re cloned and rebuilt everything again from scratch in a different location
to make sure something wasn't messed up in that specific set of sources, and I saw the same issue.
Jakub
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Monday, January 27, 2020 12:28 PM
To: Wlodek, Jakub <jwlodek at bnl.gov>
Cc: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: CAS-client thread issues in areaDetector IOC
On 1/27/20 7:45 AM, Wlodek, Jakub wrote:
> In addition, the following tests showed some error message, but were seemingly re-run successfully:
We have some tests which intentionally provoke error to ensure that
they can be handled correctly. Unless you see any "fail" instead of "ok",
then the tests are passing and we'll have to look elsewhere.
> iocshTest.t ................... 1/19 Command no_such_command not found.
> iocsh Error: Break
> Can't open no_such_file.cmd: No such file or directory
> iocshTest.t ................... ok
> chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
> chfPluginTest.t ............ ok
> netget.t ................ 1/3 **** The executable "caRepeater" couldn't be located
> **** because of errno = "No such file or directory".
> **** You may need to modify your PATH environment variable.
> **** Unable to start "CA Repeater" process.
> netget.t ................ ok
> There were also several tests that listed json parsing errors.
> Regards,
> Jakub
> *From:* Michael Davidsaver <mdavidsaver at gmail.com>
> *Sent:* Friday, January 24, 2020 4:52 PM
> *To:* Wlodek, Jakub <jwlodek at bnl.gov>
> *Cc:* Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> *Subject:* Re: CAS-client thread issues in areaDetector IOC
> On 1/24/20 10:15 AM, Mark Rivers wrote:
>> Ø Could it be that there is a problem with something in the newest release of epics-base?
>> You are running 7.0.3 now. If you go back to 7.0.3.1 does the problem re-appear?
> If the assert() failure does re-appear, could you run the base unittests and report any which don't pass?
>> make runtests
- RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
- CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
- Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
- Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
<2020>
<2020>
ANJ, 27 Jan 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
