1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: areaDetector crashes EPICS IOC and autosave failure
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Jong Woo Kim <Jong.Woo.Kim at asu.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Jong Woo Kim <jongwoo.email at gmail.com>
Date: Thu, 30 Jan 2020 17:35:26 +0000
Hi Jong Woo,
You have not told us what version of ADEiger, ADCore, EPICS base, etc. you are using.
Ø  a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message)
Did you uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugin_settings.req?
#file "sseqRecord_settings.req",     P=$(P),  S=AcquireSequence
If so you also need to uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugins.cmd
#set_requestfile_path("$(CALC)/calcApp/Db")
Ø  b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message)
Ø  ../save_restore.c(1774): [0xd]=write_it:Permission denied
That error seems pretty simple.  It is a file permission problem.  The files in that directory, or the directory itself, must not have write permission for the account that is running ADEiger application.  Fix the file permissions.
Ø  c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC (Red in the following message)
Ø  Actually data hasn't been collected
Segmentation fault (core dumped)
You have a core dump file.  You need to run gdb on that to find where it crashed.
Run this:
gdb /path/to/ADEiger_executable core.xxx
where core.xxx is the name of your core dump file.  Once you get the gdb> prompt type this command
backtrace
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Jong Woo Kim via Tech-talk
Sent: Thursday, January 30, 2020 10:33 AM
To: tech-talk at aps.anl.gov
Cc: Jong Woo Kim <Jong.Woo.Kim at asu.edu>; Jong Woo Kim <jongwoo.email at gmail.com>
Subject: areaDetector crashes EPICS IOC and autosave failure
Hello,
When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected.
In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message.
     I made sure that this file has contents and it is in a right folder
          support/calc-R3-7-3/calcApp/Db/sseq_settings.req
          support/calc-R3-7-3/db/sseq_settings.req
     It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't.
--------------------------------------------------- Message on monitor--------------------------------------------------------------
## EPICS R3.15.6
## EPICS Base built Dec  2 2019
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325'
save_restore: Can't write backup file.
2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR
EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate
Bad init_rec return value  PV: EIG1:cam1:FWClear ao: init_record
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
# Avoid deluge of messages when debugging
#dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P= EIG1:")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
epics> save_restore: Can't connect to all status PV(s)
auto_settings.sav: 1330 of 1330 PV's connected
save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357]
save_restore:write_save_file: Can't write save file. [200127-151357]
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427]
save_restore:write_save_file: Can't write save file. [200127-151427]
[iocEiger]$
Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Prev: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Next: RE: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
ANJ, 31 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
