Thank you so much. I resolved first two issues. But I'm still working on the last one 'eigerDetector crashes EPICS IOC' ( e.i. Segmentation fault (core dumped) )
I wasn't able to find where it crashed. The following is the message I've got.
Note that the version of areaDetector, ADEiger, ADCore and EPICS base are R3-7, R2-7, R3-8, 3-15-6, respectively.
We're using FileWriter interface to save data files.
$ gdb /path/to/ADEiger_executable core --- >
coredump doesn't work either
GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-115.el7
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
/path/to/ADEiger_executable: No such file or directory.
.../EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/iocBoot/iocEiger/autosave/core: No such file or directory.
(gdb)
.../systemd/coredump.conf
.../bin/coredumpctl
.../bin/systemd-coredumpctl
.../lib/systemd/systemd-coredump
.../share/bash-completion/completions/coredumpctl
.../share/man/man1/coredumpctl.1.gz
.../share/man/man5/coredump.conf.5.gz
.../share/man/man5/coredump.conf.d.5.gz
.../share/man/man8/systemd-coredump.8.gz
.../share/zsh/site-functions/_coredumpctl
.../include/config/coredump.h
.../include/config/dev/coredump.h
.../include/config/want/dev/coredump.h
.../include/linux/coredump.h
.../include/linux/devcoredump.h
.../lib/systemd/coredump
____________________________________________________________
This is one of examples that results from gdb.
$ gdb /var/lib/systemd/coredump
/var/lib/systemd/coredump: Success.
Hi Jong Woo,
You have not told us what version of ADEiger, ADCore, EPICS base, etc. you are using.
Ø
a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message)
Did you uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugin_settings.req?
#file "sseqRecord_settings.req", P=$(P), S=AcquireSequence
If so you also need to uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugins.cmd
#set_requestfile_path("$(CALC)/calcApp/Db")
Ø
b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message)
Ø
../save_restore.c(1774): [0xd]=write_it:Permission denied
That error seems pretty simple. It is a file permission problem. The files in that directory, or the directory itself, must not have write permission for the account that is running ADEiger application. Fix the file permissions.
Ø
c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC
(Red in the following message)
Ø
Actually data hasn't been collected
You have a core dump file. You need to run gdb on that to find where it crashed.
Run this:
gdb /path/to/ADEiger_executable core.xxx
where core.xxx is the name of your core dump file. Once you get the gdb> prompt type this command
backtrace
On Behalf Of Jong Woo Kim via Tech-talk
Sent: Thursday, January 30, 2020 10:33 AM
To: tech-talk at aps.anl.gov
Cc: Jong Woo Kim <Jong.Woo.Kim at asu.edu>; Jong Woo Kim <jongwoo.email at gmail.com>
Subject: areaDetector crashes EPICS IOC and autosave failure
When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected.
In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message.
I made sure that this file has contents and it is in a right folder
support/calc-R3-7-3/calcApp/Db/sseq_settings.req
support/calc-R3-7-3/db/sseq_settings.req
It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't.
--------------------------------------------------- Message on monitor--------------------------------------------------------------
## EPICS R3.15.6
## EPICS Base built Dec 2 2019
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325'
save_restore: Can't write backup file.
2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR
EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate
Bad init_rec return value PV: EIG1:cam1:FWClear ao: init_record
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
# Avoid deluge of messages when debugging
#dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P= EIG1:")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
epics> save_restore: Can't connect to all status PV(s)
auto_settings.sav: 1330 of 1330 PV's connected
save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357]
save_restore:write_save_file: Can't write save file. [200127-151357]
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427]
save_restore:write_save_file: Can't write save file. [200127-151427]
[iocEiger]$
