1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: CAS-client thread issues in areaDetector IOC
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: "Wlodek, Jakub via Tech-talk" <[email protected]>, Mark Rivers <[email protected]>, Michael Davidsaver <[email protected]>
Date: Fri, 31 Jan 2020 14:21:43 +0000
Hi all,
After updating my machine and rebooting it, then recompiling all of EPICS + modules, I ran a test by starting a simDetector IOC and letting it sit overnight.
I didn't activate any plugins or press any buttons, and when I checked on the IOC this morning, the error message was displayed several times, along with
a Segmentation Fault crash:
epics>
epics> epicsEventTrigger: pthread_mutex_lock failed: Invalid argument
epicsEventMustTriggerThread CAS-client (0x7fd6e8042940) can't proceed, suspending.
Dumping a stack trace of thread 'CAS-client':
[    0x56549c7567e3]: /epics/src/support/areaDetector/ADSimDetector/iocs/simDetectorIOC/bin/linux-x86_64/simDetectorApp(epicsStackTrace+0x73)
[    0x56549c747215]: /epics/src/support/areaDetector/ADSimDetector/iocs/simDetectorIOC/bin/linux-x86_64/simDetectorApp(cantProceed+0xc5)
[    0x56549c6d0403]: /epics/src/support/areaDetector/ADSimDetector/iocs/simDetectorIOC/bin/linux-x86_64/simDetectorApp(db_close_events+0x33)
[    0x56549c6f7d2f]: /epics/src/support/areaDetector/ADSimDetector/iocs/simDetectorIOC/bin/linux-x86_64/simDetectorApp(destroy_tcp_client+0x8f)
[    0x56549c6f894d]: /epics/src/support/areaDetector/ADSimDetector/iocs/simDetectorIOC/bin/linux-x86_64/simDetectorApp(camsgtask+0x13d)
[    0x56549c751c18]: /epics/src/support/areaDetector/ADSimDetector/iocs/simDetectorIOC/bin/linux-x86_64/simDetectorApp(start_routine+0xf8)
[    0x7fd82d7016db]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xdb)
[    0x7fd82c49688f]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
Thread CAS-client (0x7fd6e8042940) suspended
epicsEventMustTriggerThread CAS-client (0x7fd6e8042bf0) can't proceed, suspending.
Thread CAS-client (0x7fd6e8042bf0) suspended
epicsEventTrigger: pthread_mutex_unlock failed: Invalid argument
epicsEventMustTriggerThread CAS-client (0x7fd6e8043490) can't proceed, suspending.
Thread CAS-client (0x7fd6e8043490) suspended
epicsEventMustTriggerThread CAS-client (0x7fd6e8043da0) can't proceed, suspending.
Thread CAS-client (0x7fd6e8043da0) suspended
epicsEventMustTriggerThread CAS-client (0x7fd6e80446b0) can't proceed, suspending.
epicsEventMustTriggerThread CAS-client (0x7fd6e8044fc0) can't proceed, suspending.
Thread CAS-client (0x7fd6e80446b0) suspended
Thread CAS-client (0x7fd6e8044fc0) suspended
Segmentation fault (core dumped)
I still haven't been able to reproduce this on any other machines, so I may just assume that something on my test machine is broken, and I'll just move development to a
different machine until I can sort this issue out.
Jakub
From: Tech-talk <[email protected]> on behalf of Wlodek, Jakub via Tech-talk <[email protected]>
Sent: Wednesday, January 29, 2020 3:13 PM
To: Mark Rivers <[email protected]>; Michael Davidsaver <[email protected]>
Cc: [email protected] <[email protected]>
Hi all,
After testing on another Ubuntu 18 machine, I couldn't reproduce the issue. It seems that it is limited to my original specific machine. I will try updating all of the packages on it,
recompiling, and then I will use a python script to test, as suggested.
If I find the cause of the issue I will further update this thread.
Jakub
Sent: Monday, January 27, 2020 1:57 PM
To: Wlodek, Jakub <[email protected]>; Michael Davidsaver <[email protected]>
Subject: RE: CAS-client thread issues in areaDetector IOC
I suggest using the simDetector and a Python script for testing.  Start the simDetector with no plugins enabled, and have Python just press start and stop in a loop.  If that does not fail then enable plugins one at a time until you find a minimal configuration is that will generate the error.  Then others can try to reproduce.
I just did a lot of clicking on the simDetector with Ubuntu 18.04 and base 7.0.3.1 and cannot make it fail.
Sent: Monday, January 27, 2020 11:35 AM
To: Michael Davidsaver <[email protected]>
Cc: Mark Rivers <[email protected]>; [email protected]
Hi Mark
Is this error consistent or intermittent?
I observe it every time I start an IOC, but not immediately after startup, it shows up after some time with normal operation (acquire start/stop, enable/disable plugins etc.)
I can't seem to nail down a specific series of steps that leads to the error, but it seems consistent. I also re cloned and rebuilt everything again from scratch in a different location
to make sure something wasn't messed up in that specific set of sources, and I saw the same issue.
Jakub
Sent: Monday, January 27, 2020 12:28 PM
Cc: Mark Rivers <[email protected]>; [email protected] <[email protected]>
On 1/27/20 7:45 AM, Wlodek, Jakub wrote:
> In addition, the following tests showed some error message, but were seemingly re-run successfully:
We have some tests which intentionally provoke error to ensure that
they can be handled correctly.  Unless you see any "fail" instead of "ok",
then the tests are passing and we'll have to look elsewhere.
> iocshTest.t ................... 1/19 Command no_such_command not found.
> iocsh Error: Break
> Can't open no_such_file.cmd: No such file or directory
> iocshTest.t ................... ok
> chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
> chfPluginTest.t ............ ok
> netget.t ................ 1/3 **** The executable "caRepeater" couldn't be located
> **** because of errno = "No such file or directory".
> **** You may need to modify your PATH environment variable.
> **** Unable to start "CA Repeater" process.
> netget.t ................ ok
> There were also several tests that listed json parsing errors.
> Regards,
> Jakub
> *From:* Michael Davidsaver <[email protected]>
> *Sent:* Friday, January 24, 2020 4:52 PM
> *To:* Wlodek, Jakub <[email protected]>
> *Cc:* Mark Rivers <[email protected]>; [email protected] <[email protected]>
> *Subject:* Re: CAS-client thread issues in areaDetector IOC
> On 1/24/20 10:15 AM, Mark Rivers wrote:
>> Ø  Could it be that there is a problem with something in the newest release of epics-base?
>> You are running 7.0.3 now.  If you go back to 7.0.3.1 does the problem re-appear?
> If the assert() failure does re-appear, could you run the base unittests and report any which don't pass?
>> make runtests
RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Prev: RE: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Next: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Next: RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
