1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: ezca for 3.15
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "'Siddons, David'" <siddons at bnl.gov>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 3 Feb 2020 19:06:58 +0000
Hi Pete,
Rather than creating the Makefile yourself, it is easier to let EPICS create most of it for you.  I just successfully built your testenable application this way.  Here are the steps I followed.
Create a new application directory and cd to it
> mkdir testEnable
> cd testEnable
Run the makeBaseApp.pl perl script, telling it to create a caClient application type:
> /usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeBaseApp.pl -b /usr/local/epics/base-7.0.3.1 -t caClient testEnable
Go to the configure directory and edit RELEASE
> cd ../configure/
(edit RELEASE and add a line like the following to tell it to look in the EPICS extensions directory.  It will look in the include/ directory for include files and the lib/linux-x86_64 directory for libraries.
EXTENSIONS = /usr/local/epics/extensions_new
Go to the testEnableApp directory and edit the Makefile.
> cd ../testEnableApp/
(modify the provided Makefile so it looks like this)
TOP=..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
PROD_HOST += testenable
testenable_SRCS += testenable.c
testenable_LIBS += ezca
testenable_LIBS += $(EPICS_BASE_HOST_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
To avoid compiler warnings I changed your testenable.c program to declare main() to return int, and added return 0;
#include <cadef.h>
#include <ezca.h>
int main()
int d;
int s[384];
   ezcaGet("det1.TSEN", ezcaLong, 384, &s);
   ezcaGet("det1.CHAN",ezcaLong,1,&d);
   s[d]=1;
  ezcaPut("det1.TSEN", ezcaLong, 1, s);
  return 0;
} /* end main() */
Then I just typed "make" and it built fine.
corvette:~/devel/testEnable/testEnableApp>make
perl -CSD /usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory `/home/epics/devel/testEnable/testEnableApp/O.linux-x86_64'
perl -CSD /usr/local/epics/base-7.0.3.1/bin/linux-x86_64/mkmf.pl  -m testenable.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/usr/local/epics/extensions_new/include -I/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/usr/local/epics/base-7.0.3.1/include/os/Linux -I/usr/local/epics/base-7.0.3.1/include        testenable.o ../testenable.c
make[1]: Leaving directory `/home/epics/devel/testEnable/testEnableApp/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/usr/local/epics/extensions_new/include -I/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/usr/local/epics/base-7.0.3.1/include/os/Linux -I/usr/local/epics/base-7.0.3.1/include        -c ../testenable.c
/usr/bin/g++ -o testenable  -L/home/epics/devel/testEnable/lib/linux-x86_64 -L/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -L/usr/local/epics/extensions_new/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/testEnable/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions_new/lib/linux-x86_64           -rdynamic -m64         testenable.o    -lezca -lca -lCom
Installing created executable ../../bin/linux-x86_64/testenable
Sent: Monday, February 3, 2020 11:51 AM
To: Mark Rivers <rivers at cars.uchicago.edu>
Subject: Re: ezca for 3.15
Hi Mark,
   Added cadef.h and get:
gcc -c -fPIC -I/home/peter/epics/extensions/include -I/home/peter/epics/base/include -I/home/peter/epics/base/include/os/Linux testenable.c
In file included from /home/peter/epics/base/include/epicsTypes.h:19:0,
                 from /home/peter/epics/base/include/caerr.h:31,
                 from /home/peter/epics/base/include/cadef.h:48,
                 from testenable.c:1:
/home/peter/epics/base/include/compilerDependencies.h:19:10: fatal error: compilerSpecific.h: No such file or directory
 #include "compilerSpecific.h"
compilation terminated.
I hacked a Makefile, and the above was generated when I used it. I got the same error when I used the single compile line I had before. I've attached the c file and the makefile. Any suggestions?
Pete.
From: Mark Rivers <mailto:rivers at cars.uchicago.edu>
Sent: Saturday, February 1, 2020 5:13 PM
To: Siddons, David <mailto:siddons at bnl.gov>
Cc: tech-talk <mailto:tech-talk at aps.anl.gov>
Hi Peter,
You need this to add this line in your program:
#include <cadef.h>
before
#include <ezca.h>
Because ezca.h uses chid, it should really be including cadef itself.  But it doesn't.
Sent: Saturday, February 1, 2020 3:53 PM
To: Mark Rivers
Cc: tech-talk
Hi Mark,
   OK, I rebuilt my extensions directory, and built ezca. All went well. When I try to use ezca I hit problems. Here is my simple program; it reads a vector, changes one element and then writes it back:
#include <ezca.h>
main()
int d;
int s[384];
   s[d]=1;
and my compile line:
gcc -o testenable -L/home/peter/epics/extensions-master/lib -I/home/peter/epics/extensions-master/include -I//home/peter/epics/base-3.15.6/include/ -lezca testenable.c
which gets me:
In file included from testenable.c:1:0:
/home/peter/epics/extensions-master/include/ezca.h:77:61: error: unknown type name ‘chid’; did you mean ‘void’?
 epicsShareFunc int epicsShareAPI ezcaPvToChid(char *pvname, chid **cid);
                                                             void
/home/peter/epics/extensions-master/include/ezca.h:103:2: error: unknown type name ‘TS_STAMP’
  TS_STAMP *timestamp, short *status, short *severity);
/home/peter/epics/extensions-master/include/ezca.h:107:45: error: unknown type name ‘TS_STAMP’
  char ezcatype, int nelem, void *data_buff, TS_STAMP *timestamp,
testenable.c:2:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
 main()
So what am I doing wrong?
Pete.
Sent: Saturday, February 1, 2020 3:56 PM
Hi Pete,
I suspect you may be using an old version of ezca?  The latest version is here:
https://github.com/epics-extensions/extensions
<https://github.com:epics-extensions/extensions>
I just built successfully with that version on base 7.0.3.1, so I am pretty sure 3.15 will build fine as well.
Here is the output when building:
corvette:extensions_new/src/ezca>make
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[1]: Entering directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/mkmf.pl  -m ezca.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           ezca.o ../ezca.c
make[1]: Leaving directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           -c ../ezca.c
../ezca.c: In function 'pop_channel':
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
    sizeof(struct channel)*NODESPERMAL, Channel_avail_hdr);
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_monitor':
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct monitor)*NODESPERMAL, Monitor_avail_hdr);
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_work':
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct work)*NODESPERMAL, Work_avail_hdr);
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
/usr/bin/ar -rc    libezca.a    ezca.o
/usr/bin/ranlib libezca.a
/usr/bin/g++ -o libezca.so -shared -fPIC -Wl,-hlibezca.so -L/usr/local/epics/extensions_new/lib/linux-x86_64 -L/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions_new/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-7.0.3.1/lib/linux-x86_64           -rdynamic -m64         ezca.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libezca.so
Installing library ../../../lib/linux-x86_64/libezca.a
Cheers,
From: Tech-talk <mailto:tech-talk-bounces at aps.anl.gov> on behalf of Siddons, David via Tech-talk <mailto:tech-talk at aps.anl.gov>
Sent: Saturday, February 1, 2020 2:33 PM
To: EPICS Tech Talk
Subject: ezca for 3.15
I want to use ezca with 3.15, but it seems to be a mess of missing header files, presumably things dropped with 3.15 (e.g. tsDefs.h, cadef.h). Has anyone made it work?
Pete.
Re: ezca for 3.15 D. Peter Siddons via Tech-talk
ezca for 3.15 Siddons, David via Tech-talk
Re: ezca for 3.15 Mark Rivers via Tech-talk
Re: ezca for 3.15 Siddons, David via Tech-talk
Prev: Re: ezca for 3.15 Siddons, David via Tech-talk
Next: Re: ezca for 3.15 D. Peter Siddons via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 03 Feb 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
