Subject: RE: Loading NDOverlayN.template
To: "'Miceli, Antonino'" <[email protected]>
Cc: "[email protected]" <[email protected]>, "Piatak, Christopher" <[email protected]>
Date: Wed, 5 Feb 2020 22:20:24 +0000
Hi Nino,
There are no macros for the XWIDTH and YWIDTH.  They can be set in the GUI and then will be in autosave.  Or you can do a dbpf to those PVs at the end of the startup script.
[X,Y]Width=0 is not recommended.  The behavior of the [X,Y]Width is documented here: https://areadetector.github.io/master/ADCore/NDPluginOverlay.html. It says:
The X line width of this overlay. For the cross overlay this will increase the width of the line on both sides at the same time, to maintain the central point of the cross. For the rectangle and ellipse overlays the line thickness will grow inwards to the center. For cross overlay shapes the widths >1 are restricted to even numbers; odd widths >1 are decreased by 1.
From: Tech-talk <[email protected]> On Behalf Of Miceli, Antonino via Tech-talk
Sent: Wednesday, February 5, 2020 3:33 PM
To: [email protected] >> EPICS Tech Talk <[email protected]>
Cc: Piatak, Christopher <[email protected]>
Subject: Loading NDOverlayN.template
We are trying to load overlays in AD and would like to change the X and Y widths to be non-zero (this causes endless problems from users since a rectangular overlap won't display with width =0, but a cross will!).
I would guess that I just have to say YWIDTH=1, XWIDTH=1 but this does not seem to work. For example, in the commonPlugins.cmd:
dbLoadRecords("NDOverlayN.template","P=$(PREFIX),R=Over1:1:, NAME=Box1,  YWIDTH=1, XWIDTH=1,SHAPE=1,O=Over1:, XPOS=$(PREFIX)ROI1:MinX_RBV,  YPOS=$(PREFIX)ROI1:MinY_RBV,  XSIZE=$(PREFIX)ROI1:SizeX_RBV,  YSIZE=$(PREFIX)ROI1:SizeY_RBV,  PORT=OVER1,ADDR=0, TIMEOUT=1")
Advise?
Nino
Loading NDOverlayN.template Miceli, Antonino via Tech-talk
Prev: RE: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Next: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Prev: Loading NDOverlayN.template Miceli, Antonino via Tech-talk
Next: ThorLabs motor driver Valentyn Stadnytskyi via Tech-talk
