Subject: RE: SNCSEQ Error Windows
From: Freddie Akeroyd - UKRI STFC via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Wed, 12 Feb 2020 01:31:30 +0000
If I unpack seq 2.2.8 into the epics-base/modules area I get the same build error as mentioned for the example with epics 7 (master). If I move the seq directory to outside of the modules area, then everything works fine.
What I think is happening is that when seq 2.2.8 is placed in the epics-base/modules area its binaries are installed into epics-base/bin rather than seq/bin. The .st/.stt compile rules for the seq assume the snc executable is installed in $(SNCSEQ)/bin and so they then fail.
The CONFIG_SITE.local  in epics-base/modules sets INSTALL_LOCATION to epics-base/bin, in seq 2.2.8 its CONFIG_SITE includes $(TOP)/../ CONFIG_SITE.local whereas in 2.2.5 this is not done, which I suspect is why seq 2.2.5 works ok.
Freddie
-----Original Message-----
Sent: 11 February 2020 15:13
Cc: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
Subject: Re: SNCSEQ Error Windows
Am 11.02.20 um 15:21 schrieb Hetz, Benjamin via Tech-talk:
> Strange using 2.2.5 works like a charm. 2.2.8 not.
Indeed this is quite strange. The build rules haven't changed at all between 2.2.5 and 2.2.8.
Freddie, can you look into that? I cannot reproduce the problem on Linux.
>>> I am using the Windows build of EPICS with VS compiler and Strawbery Perl.
>>> Compiling SNCSeq 2.2.8 went fine and also its demo/example files
>>> were build in seq-2_2_8\examples and running.
>>> Following the instruction from https://www-
>>> csr.bessy.de/control/SoftDist/sequencer/Compiling.html I created an
>>> example IOC and changed SNCSEQ in configure/REALESE to
>>> "C:/opt/epics/base-7_0_3/modules/seq-2_2_8".
>>> Running now gmake in the example ioc top dir yields following error:
>>> gmake[3]: *** No rule to make target 'sncExample.obj', needed by
>>> 'interlocksSupport.lib'.  Stop.
>>> gmake[3]: Leaving directory
>>> 'C:/opt/epics/interlocks/interlocksApp/src/O.windows-x64-static'
>>> gmake[2]: *** [C:/opt/epics/base-7_0_3/configure/RULES_ARCHS:58:
>>> install.windows-x64-static] Error 2
>>> gmake[2]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp/src'
>>> gmake[1]: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84:
>>> src.install] Error 2
>>> gmake[1]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp'
>>> gmake: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84:
>>> interlocksApp.install] Error 2
>>> May anyone please help?
>>> Thank you, Ben
Re: SNCSEQ Error Windows Benjamin Franksen via Tech-talk
SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Re: SNCSEQ Error Windows Mark Rivers via Tech-talk
RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Prev: Re: Standard RTEMS NFSv3 client Matt Newville via Tech-talk
Next: Re: Standard RTEMS NFSv3 client Heinz Junkes via Tech-talk
Prev: Re: SNCSEQ Error Windows Benjamin Franksen via Tech-talk
Next: Re: SNCSEQ Error Windows Benjamin Franksen via Tech-talk
