Subject: EPICS Archiver appliance MySQL Persistence error
From: Peter Linardakis via Tech-talk <[email protected]>
Date: Thu, 20 Feb 2020 05:14:53 +0000
Hi all
Attempted to build a single machine installation of an EPICS archiver appliance using the install_scripts/single_machine_install.sh script.  Everything seemed to go OK with the install and the management URL displays correctly, except there are errors as below, which also show when you attempt to add a PV.  The MySQL daemon is running and I have added a connection pool to conf/contect.xml as per https://slacmshankar.github.io/epicsarchiver_docs/installguide.html (although the error is identical without it).
mysql-connector-java-8.0.19.jar is installed under /opt/archappl/tomcatinstances/apache-tomcat-9.0.31/lib/
…/mgmt/logs/arch.log
0    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Archiver Appliance Version 0.0.1_SNAPSHOT_13-November-2019T15-45-42
1    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
28   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://nucserver4:17665/mgmt/bpl
29   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties from the webapp classpath /opt/archappl/tomcatinstances/mgmt/webapps/mgmt/WEB-INF/classes/archappl.properties
30   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/tomcatinstances/mgmt/webapps/mgmt/WEB-INF/classes/archappl.properties
11333 [Startup executor] INFO  config.org.epics.archiverappliance.config.persistence.MySQLPersistence  - Looking up datasource called jdbc/archappl in the java:/comp/env namespace using JDNI
11334 [Startup executor] INFO  config.org.epics.archiverappliance.config.persistence.MySQLPersistence  - Found datasource called jdbc/archappl in the java:/comp/env namespace using JDNI
11335 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading PVTypeInfo from persistence
11347 [Startup executor] ERROR config.org.epics.archiverappliance.config.DefaultConfigService  - Exception loading PVs from persistence java.io.IOException: java.sql.SQLException: Cannot create JDBC driver of class '' for connect URL 'null'
        at org.epics.archiverappliance.config.persistence.MySQLPersistence.getKeys(MySQLPersistence.java:145)
        at org.epics.archiverappliance.config.persistence.MySQLPersistence.getTypeInfoKeys(MySQLPersistence.java:51)
Relevant lines form the startup file are:
export JAVA_HOME=/usr/lib/jvm/jdk-13.0.2
export TOMCAT_HOME=/opt/archappl/tomcatinstances/apache-tomcat-9.0.31
export ARCHAPPL_DEPLOY_DIR=/opt/archappl/tomcatinstances
export ARCHAPPL_APPLIANCES=/opt/archappl/tomcatinstances/appliances.xml
export ARCHAPPL_MYIDENTITY="appliance0"
Am I missing something basic?
Regards
Peter
Dr Peter Linardakis
Senior Accelerator R&D Engineer
Nuclear Physics | Research School of Physics
Australian National University
Re: EPICS Archiver appliance MySQL Persistence error Heinz Junkes via Tech-talk
Prev: RE: matrix multiplication and inversions [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Next: MEMD is stuck on windows-x64 杨栋亮 via Tech-talk
Next: Re: EPICS Archiver appliance MySQL Persistence error Heinz Junkes via Tech-talk
