1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Problem in installing synApps_6_0
From: Kim SeongBin via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 24 Feb 2020 18:00:29 +0900
I am using the Fedora 28.
I am facing the following error messages when installing synApps_6_0 with EPICS base 3.15.5.
Please help me.
Seongbin Kim
gmake -C asyn/asynPortDriver/unittest install
gmake[1]: Entering directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest'
perl -CSD /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir O.Common
gmake -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 install
gmake[2]: Entering directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic
 -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include
 -I/usr/local/epics/extensions/src/synApps_6_0/support//ipac-2-15/include   -I/usr/local/epics/extensions/src/synApps_6_0/support//seq-2-2-5/include
 -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include
 -MM -MF asynPortDriverTest.d  ../asynPortDriverTest.cpp
 -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include        -c ../asynPortDriverTest.cpp
/usr/bin/g++ -o asynPortDriverTest  -L/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64
 -L/usr/local/epics/base-3.15.5/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64 -Wl,
-rpath,/usr/local/epics/base-3.15.5/lib/linux-x86_64           -rdynamic -m64            asynPortDriverTest.o    -lasyn -lCom
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bytes'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_free'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_sperror'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bool'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_int'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_spcreateerror'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_string'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_void'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_enum'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnttcp_create'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_char'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_int'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_short'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_char'
collect2: error: ld returned 1 exit status
gmake[2]: *** [/usr/local/epics/base/configure/RULES_BUILD:202: asynPortDriverTest] Error 1
gmake[2]: Leaving directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest/O.linux-x86_64'
gmake[1]: *** [/usr/local/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
gmake[1]: Leaving directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest'
gmake: *** [/usr/local/epics/base/configure/RULES_DIRS:84: asyn/asynPortDriver/unittest.install] Error 2
Re: Problem in installing synApps_6_0 Mooney, Tim M. via Tech-talk
Prev: RE: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
Next: Re: Areadetector error in version R3-8 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: Re: Problem in installing synApps_6_0 Mooney, Tim M. via Tech-talk
ANJ, 25 Feb 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
