Subject: Re: Problem in installing synApps_6_0
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Kim SeongBin <[email protected]>
Date: Mon, 24 Feb 2020 17:13:16 +0000
I think you probably need to edit configure/CONFIG_SITE, and uncomment the line
# TIRPC=YES
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Kim SeongBin via Tech-talk <[email protected]>
Sent: Monday, February 24, 2020 3:00 AM
To: [email protected] <[email protected]>
Subject: Problem in installing synApps_6_0
I am using the Fedora 28.
I am facing the following error messages when installing synApps_6_0 with EPICS base 3.15.5.
Please help me.
Seongbin Kim
gmake -C asyn/asynPortDriver/unittest install
gmake[1]: Entering directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest'
perl -CSD /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir O.Common
gmake -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 install
gmake[2]: Entering directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic
 -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include
 -I/usr/local/epics/extensions/src/synApps_6_0/support//ipac-2-15/include   -I/usr/local/epics/extensions/src/synApps_6_0/support//seq-2-2-5/include
 -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include
 -MM -MF asynPortDriverTest.d  ../asynPortDriverTest.cpp
 -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include        -c ../asynPortDriverTest.cpp
/usr/bin/g++ -o asynPortDriverTest  -L/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64
 -L/usr/local/epics/base-3.15.5/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64 -Wl,
-rpath,/usr/local/epics/base-3.15.5/lib/linux-x86_64           -rdynamic -m64            asynPortDriverTest.o    -lasyn -lCom
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bytes'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_free'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_sperror'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bool'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_int'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_spcreateerror'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_string'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_void'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_enum'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnttcp_create'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_char'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_int'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_short'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_char'
collect2: error: ld returned 1 exit status
gmake[2]: *** [/usr/local/epics/base/configure/RULES_BUILD:202: asynPortDriverTest] Error 1
gmake[2]: Leaving directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest/O.linux-x86_64'
gmake[1]: *** [/usr/local/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
gmake[1]: Leaving directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest'
gmake: *** [/usr/local/epics/base/configure/RULES_DIRS:84: asyn/asynPortDriver/unittest.install] Error 2
Re: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
Prev: Re: firewalld configuration for EPICS? Gabriel Fedel via Tech-talk
Next: asyn R4-39 available Mark Rivers via Tech-talk
Prev: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
Next: Re: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
