Subject: RE: pco Camera USB and IEEE interface
To: "Sintschuk, Michael" <[email protected]>
Date: Fri, 28 Feb 2020 14:30:09 +0000
Hi Michael,
I just tried building ADPcoWin  with the windows-x64 architecture and Visual Studio 2015. I get the same error you do.  I was able to fix that error, but then ran into a more fundamental problem.  When building dynamically the vendor libraries need to be linked with using LIB_LIBS.  The pcowinApp/src/Makefile installs those vendor libraries using LIB_INSTALLS and BIN_INSTALLS.  However, the LIB_INSTALLS and BIN_INSTALLS operations happen after the library is built, not before, so it is too late and the link operation fails.  The Makefile also was not linking the library with ADCore, asyn, vendor libraries, etc.
Clearly dynamic builds of ADPcoWin had never been tested.
I am working on a fix, but meanwhile if you build with EPICS_HOST_ARCH=windows-x64-static it should work.  It just worked OK for me with Visual Studio 2015.
Sent: Wednesday, February 26, 2020 10:20 AM
To: Sintschuk, Michael <[email protected]>
Cc: [email protected]
Subject: Re: pco Camera USB and IEEE interface
I have built this on the windows-x64-static architecture with VS2015.
Can you try building windows-x64-static rather than windows-x64 (dynamic)?
Sent: Wednesday, February 26, 2020 9:44 AM
To: Mark Rivers
Cc:
[email protected]
Subject: AW: pco Camera USB and IEEE interface
Hi Mark,
ok, now I took the latest master-branch release and got a little further:
make -C C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin install
make[1]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin'
make -C ./configure install
make[2]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure'
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[3]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64'
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/convertRelease.pl checkRelease
make[3]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64'
make[2]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure'
make -C ./pcowinApp install
make[2]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp'
make -C ./src install
make[3]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src'
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src/O.windows-x64'
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m PcoApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:/e
pics/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst-3.15.
7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    PcoApi.obj ../PcoA
pi.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m NdArrayRef.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I
C:/epics/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst-3
.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    NdArrayRef.obj
 ../NdArrayRef.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m ADDriverEx.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I
.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    ADDriverEx.obj
 ../ADDriverEx.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m PcoCameraDevice.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
   -IC:/epics/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/i
nst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    PcoCamera
Device.obj ../PcoCameraDevice.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m AsynParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC
:/epics/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst-3.
15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    AsynParam.obj .
./AsynParam.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m StringParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -
IC:/epics/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst-
3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    StringParam.o
bj ../StringParam.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m DoubleParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -
3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    DoubleParam.o
bj ../DoubleParam.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m IntegerParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
-IC:/epics/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst
-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    IntegerParam
.obj ../IntegerParam.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m FreeLock.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:
/epics/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst-3.1
5.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    FreeLock.obj ../
FreeLock.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m TakeLock.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:
5.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    TakeLock.obj ../
TakeLock.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m SimulationApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
t-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    SimulationA
pi.obj ../SimulationApi.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m PcoException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    PcoException
.obj ../PcoException.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m PerformanceMonitor.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
s/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    Perfor
manceMonitor.obj ../PerformanceMonitor.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m SocketProtocol.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
st-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    SocketProt
ocol.obj ../SocketProtocol.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m GangServerConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    GangServ
erConfig.obj ../GangServerConfig.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m GangMemberConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    GangMemb
erConfig.obj ../GangMemberConfig.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m GangConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I
.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    GangConfig.obj
 ../GangConfig.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m GangConnection.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
st-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    GangConnec
tion.obj ../GangConnection.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m GangClient.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I
.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    GangClient.obj
 ../GangClient.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m GangServer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I
.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    GangServer.obj
 ../GangServer.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m TraceStream.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -
3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    TraceStream.o
bj ../TraceStream.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m StateMachine.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    StateMachine
.obj ../StateMachine.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m AsynException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
t-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    AsynExcepti
on.obj ../AsynException.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m NDArrayException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    NDArrayE
xception.obj ../NDArrayException.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m DllApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:/e
7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    DllApi.obj ../DllA
pi.cpp
perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl  -m Pco.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:/epic
s/inst-3.15.7/asyn-R4-37/include     -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst-3.15.7/a
reaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    Pco.obj ../Pco.cpp
"Installing dbd file ../../../dbd/pcowinSupport.dbd"
mkdir ../../../dbd
"Installing dbd file ../../../dbd/pcowinHardwareSupport.dbd"
cl -EHsc -GR            /O2 /wd4290     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_
DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:/epics/inst-3.15.7/asyn-R4-37/include     -I
C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include   -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../Pco.cpp
Pco.cpp
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\Pco.cpp(1701): warning C4838: Konvertierung von "int" zu "size_t" erfordert eine einschränkende Konvertierung
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\Pco.cpp(2531): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\Pco.cpp(2532): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../DllApi.cpp
DllApi.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../NDArrayException.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../AsynException.cpp
AsynException.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../StateMachine.cpp
StateMachine.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../TraceStream.cpp
TraceStream.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../GangServer.cpp
GangServer.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../GangClient.cpp
GangClient.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../GangConnection.cpp
GangConnection.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../GangConfig.cpp
GangConfig.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../GangMemberConfig.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../GangServerConfig.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../SocketProtocol.cpp
SocketProtocol.cpp
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\SocketProtocol.cpp(193): warning C4996: 'gethostbyname': Use getaddrinfo() or GetAddrInfoW() instead or define _WINSOCK_DEPRECAT
ED_NO_WARNINGS to disable deprecated API warnings
C:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\um\winsock2.h(2219): note: Siehe Deklaration von "gethostbyname"
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../PerformanceMonitor.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../PcoException.cpp
PcoException.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../SimulationApi.cpp
SimulationApi.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../TakeLock.cpp
TakeLock.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../FreeLock.cpp
FreeLock.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../IntegerParam.cpp
IntegerParam.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../DoubleParam.cpp
DoubleParam.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../StringParam.cpp
StringParam.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../AsynParam.cpp
AsynParam.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../PcoCameraDevice.cpp
PcoCameraDevice.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../ADDriverEx.cpp
ADDriverEx.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../NdArrayRef.cpp
NdArrayRef.cpp
ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include     -I../include/    -c ../PcoApi.cpp
PcoApi.cpp
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\ATLMFC\include\afx.h(24): fatal error C1189: #error:  Building MFC application with /MD[d] (CRT dll ve
rsion) requires MFC shared dll version. Please #define _AFXDLL or do not use /MD[d]
make[4]: *** [C:/epics/base-3.15.7/configure/RULES_BUILD:240: PcoApi.obj] Error 2
make[4]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src/O.windows-x64'
make[3]: *** [C:/epics/base-3.15.7/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[3]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src'
make[2]: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: src.install] Error 2
make[2]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp'
make[1]: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: pcowinApp.install] Error 2
make[1]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin'
make: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin.install] Error 2
Still there is an error.
Has someone ever compiled this package with the setup I have: windows 7 64bit, Microsoft Visual Studio\2019\Community ?
Michael
Von: Mark Rivers <[email protected]>
Gesendet: Mittwoch, 26. Februar 2020 13:53:11
An: Sintschuk, Michael
Cc:
[email protected]
Betreff: Re: pco Camera USB and IEEE interface
Hi Michael,
I believe all of the errors that you are getting are because you are not using the master branch of ADPcoWin. In particular you are missing this commit:
commit 950dbdd9471184e4f6c428051ae982544272e8cd
Author: Mark Rivers <
[email protected]>
Date:   Mon Mar 25 08:23:18 2019 -0500
    Add <algorithm> include; change NDArrayPool buffer functions for new versions
Including <algorithm> should eliminate these errors:
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2545): error C2039: "min": Ist kein Element von "std"
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2545): error C3861: "min": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2546): error C2039: "max": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2546): error C3861: "max": Bezeichner wurde nicht gefunden.
The changes to NDArrayPool in that commit should eliminate these errors:
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1525): error C2039: "numBuffers": Ist kein Element von "NDArrayPool"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADCore\include\NDArray.h(161): note: Siehe Deklaration von "NDArrayPool"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1525): error C2039: "numFree": Ist kein Element von "NDArrayPool"
Note that there are lots of other commits since March 25, 2019 as well.  However, the last release was 4.0 on February 27, 2019.  It looks like there should probably be a new release of this module.  The folks from Diamond (Ben Bradnick, Ulrik Pederson, and others) are in charge of this module.
Meanwhile try using the master branch.
[email protected]>
Sent: Wednesday, February 26, 2020 5:30 AM
To: Mark Rivers
Cc:
[email protected]
Hi Mark,
I followed your advice and recompiled my EPICS-base 3.15.7 and the required modules asyn, calc ... etc. that are needed for areaDetector with Microsoft Visual Studio-2019 Community-Edition (x64) succesfully.
However when I make areaDetector with all the standard-settings described in the Installation-Guide, it runs about 5min until it gets to the ADPcoWin-module and crashes with the following errors:
make[1]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADCore'
make[3]: Nothing to be done for 'install'.
make -C ./pcocam2App install
make[2]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App'
make[3]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src'
make[4]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64'
:/epics/inst-3.15.7/asyn-R4-37/include   -IC:/epics/inst-3.15.7/calc-R3-7-3/include   -IC:/epics/inst-3.15.7/sscan-R2-11-3/include   -IC:/epics/inst-3.15.7/busy-R1-7-2/include   -IC:/epics/i
nst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    PcoApi
.obj ../PcoApi.cpp
 -IC:/epics/inst-3.15.7/asyn-R4-37/include   -IC:/epics/inst-3.15.7/calc-R3-7-3/include   -IC:/epics/inst-3.15.7/sscan-R2-11-3/include   -IC:/epics/inst-3.15.7/busy-R1-7-2/include   -IC:/epi
cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    Nd
ArrayRef.obj ../NdArrayRef.cpp
cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    AD
DriverEx.obj ../ADDriverEx.cpp
-IC:/epics/inst-3.15.7/asyn-R4-37/include   -IC:/epics/inst-3.15.7/calc-R3-7-3/include   -IC:/epics/inst-3.15.7/sscan-R2-11-3/include   -IC:/epics/inst-3.15.7/busy-R1-7-2/include   -IC:/epic
s/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    Asy
nParam.obj ../AsynParam.cpp
ics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    S
tringParam.obj ../StringParam.cpp
ics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    D
oubleParam.obj ../DoubleParam.cpp
pics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/
IntegerParam.obj ../IntegerParam.cpp
IC:/epics/inst-3.15.7/asyn-R4-37/include   -IC:/epics/inst-3.15.7/calc-R3-7-3/include   -IC:/epics/inst-3.15.7/sscan-R2-11-3/include   -IC:/epics/inst-3.15.7/busy-R1-7-2/include   -IC:/epics
/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    Free
Lock.obj ../FreeLock.cpp
/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    Take
Lock.obj ../TakeLock.cpp
epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/
 SimulationApi.obj ../SimulationApi.cpp
PcoException.obj ../PcoException.cpp
-IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../includ
e/    PerformanceMonitor.obj ../PerformanceMonitor.cpp
/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/
  SocketProtocol.obj ../SocketProtocol.cpp
C:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/
    GangServerConfig.obj ../GangServerConfig.cpp
    GangMemberConfig.obj ../GangMemberConfig.cpp
cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    Ga
ngConfig.obj ../GangConfig.cpp
  GangConnection.obj ../GangConnection.cpp
ngClient.obj ../GangClient.cpp
ngServer.obj ../GangServer.cpp
ics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    T
raceStream.obj ../TraceStream.cpp
StateMachine.obj ../StateMachine.cpp
 AsynException.obj ../AsynException.cpp
    NDArrayException.obj ../NDArrayException.cpp
nst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    DllApi
.obj ../DllApi.cpp
pics/inst-3.15.7/asyn-R4-37/include   -IC:/epics/inst-3.15.7/calc-R3-7-3/include   -IC:/epics/inst-3.15.7/sscan-R2-11-3/include   -IC:/epics/inst-3.15.7/busy-R1-7-2/include   -IC:/epics/inst
-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    Pco.obj .
./Pco.cpp
"Installing dbd file ../../../dbd/pcocam2Support.dbd"
mkdir ../../../dbd
"Installing dbd file ../../../dbd/pcocam2HardwareSupport.dbd"
IC:/epics/inst-3.15.7/calc-R3-7-3/include   -IC:/epics/inst-3.15.7/sscan-R2-11-3/include   -IC:/epics/inst-3.15.7/busy-R1-7-2/include   -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/includ
e -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include        -I../include/    -c ../Pco.cpp
Pco.cpp
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1701): warning C4838: Konvertierung von "int" zu "size_t" erfordert eine einschränkende Konvertierung
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2527): error C2039: "max": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2527): error C3861: "max": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2528): error C2039: "min": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2528): error C3861: "min": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2529): error C2039: "max": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2529): error C3861: "max": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2530): error C2039: "min": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2530): error C3861: "min": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2533): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2534): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2542): error C2039: "max": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2542): error C3861: "max": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2543): error C2039: "min": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2543): error C3861: "min": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2544): error C2039: "max": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2544): error C3861: "max": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2547): error C2039: "min": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2547): error C3861: "min": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2548): error C2039: "max": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2548): error C3861: "max": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2549): error C2039: "min": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2549): error C3861: "min": Bezeichner wurde nicht gefunden.
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2723): error C2039: "max": Ist kein Element von "std"
C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2723): error C3861: "max": Bezeichner wurde nicht gefunden.
make[4]: *** [C:/epics/base-3.15.7/configure/RULES_BUILD:240: Pco.obj] Error 2
make[4]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64'
make[3]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src'
make[2]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App'
make[1]: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: pcocam2App.install] Error 2
The errors are in german but I think quite understandable...
I already tried it with adding some extra MSVC-packages for my visual studio: one can adjust the Microsoft Visual Studio - Edition with the Visual Studio Installer. So my folder C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC contains not only 14.24.28314 but also 14.23.28105 ;  14.22.27905 ; 14.21.27702 ; 14.20.27508. But with no success.
Before I start to make, I run the windows.bat file, located in C:\epics\base-3.15.7\startup , which I edited the following way:
@echo off
rem *************************************************************************
rem  Copyright (c) 2017 UChicago Argonne LLC, as Operator of Argonne
rem      National Laboratory.
rem  Copyright (c) 2002 The Regents of the University of California, as
rem      Operator of Los Alamos National Laboratory.
rem  EPICS BASE is distributed subject to a Software License Agreement found
rem  in file LICENSE that is included with this distribution.
rem
rem Site-specific EPICS environment settings
rem
rem Sets EPICS_HOST_ARCH and the environment for Microsoft Visual Studio.
rem Optionally, resets PATH, adds Strawberry Perl to PATH, and adds the
rem EPICS Base install host architecture bin directory to PATH.
rem
rem ----------------------------------------------------------------------
rem Site serviceable parts (These definitions may be modified)
rem The values of the definitions in this section must not contain
rem double-quotes.
rem
rem * Right: set _foo=C:\foo
rem * Right: set "_foo=C:\foo"
rem * Wrong: set _foo="C:\foo"
rem Automatically set up the environment when possible ("yes" or "no").
rem If set to yes, as much of the environment will be set up as possible.
rem If set to no, just the minimum environment will be set up.  More
rem specific _auto_* definitions take precedence over this definition.
set _auto=no
rem Automatically reset PATH ("yes" or "no").  If set to yes, PATH will
rem be reset to the value of _path_new.  If set to no, PATH will not be
rem reset.
set _auto_path_reset=%_auto%
rem Automatically append to PATH ("yes" or "no").  If set to yes, the
rem EPICS Base install host architecture bin directory will be added to
rem PATH if possible.  If set to no, the bin directory will not be added
rem to PATH.
set _auto_path_append=%_auto%
rem The new value for PATH.  If _auto_path_reset is yes, PATH will be set
rem to it.
set _path_new=C:\Windows\System32;C:\Windows;C:\Windows\System32\wbem
rem The location of Strawberry Perl (pathname).  If empty, Strawberry Perl
rem is assumed to already be in PATH and will not be added.  If nonempty,
rem Strawberry Perl will be added to PATH.
set _strawberry_perl_home=C:\Strawberry
rem The location of Microsoft Visual Studio (pathname).
set _visual_studio_home=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community
rem The EPICS host architecture specification for EPICS_HOST_ARCH
rem (<os>-<arch>[-<toolset>] as defined in configure/CONFIG_SITE).
set _epics_host_arch=windows-x64
rem The install location of EPICS Base (pathname).  If nonempty and
rem _auto_path_append is yes, it will be used to add the host architecture
rem bin directory to PATH.
set _epics_base=C:\epics\base-3.15.7
rem Internal parts (There is typically no need to modify these)
rem Reset PATH
if "%_auto_path_reset%" == "yes" (
  set "PATH=%_path_new%"
rem Add Strawberry Perl to PATH
if "%_strawberry_perl_home%" == "" goto after_add_strawberry_perl
rem Can't do this inside parentheses because PATH would be read only once
set "PATH=%PATH%;%_strawberry_perl_home%\c\bin"
set "PATH=%PATH%;%_strawberry_perl_home%\perl\site\bin"
set "PATH=%PATH%;%_strawberry_perl_home%\perl\bin"
:after_add_strawberry_perl
rem Set the environment for Microsoft Visual Studio
call "%_visual_studio_home%\VC\Auxiliary\Build\vcvarsall.bat" x64
rem Set the EPICS host architecture specification
set "EPICS_HOST_ARCH=%_epics_host_arch%"
rem Add the EPICS Base host architecture bin directory to PATH
if "%_auto_path_append%" == "yes" (
  if not "%_epics_base%" == "" (
    set "PATH=%PATH%;%_epics_base%\bin\%_epics_host_arch%"
rem Don't leak variables into the environment
set _auto=
set _path_new=
set _epics_base=
It worked with all the other compilations so far...
Thanks in advance.
Michael
Gesendet: Dienstag, 28. Januar 2020 19:19:26
Betreff: RE: pco Camera USB and IEEE interface
Hi Michael,
Ø  I'm trying to install the areaDetector module with the help of this guide:
Ø
https://areadetector.github.io/master/install_guide.html
Ø  and with the ADPcoWin package. At some point I get the following errors:
It looks like you are compiling ADPcoWin with mingw and not Visual Studio.  I doubt if anyone has tried that, and it may well not work.
In addition, your configuration of mingw is setting the /O2 /wd4290 flags, but mingw is misinterpreting those as directories, not flags.
I don't see those flags in EPICS base/configure/os, so they must be coming from somewhere else?
If you can figure out how to get rid of the /O2 and /wd4290 flags you may be able to build it with mingw.
If not, I suggest installing Visual Studio Community Edition (free) and compiling with that.
Sent: Tuesday, January 28, 2020 10:42 AM
Hello again,
make[1]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADCore'
C:/Strawberry/c/bin/make -C /epics/modules/areaDetector-R3-8/ADPcoWin install
make[1]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin'
C:/Strawberry/c/bin/make -C ./configure install
make[2]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure'
perl -CSD C:/epics/base-3.15.7/bin/windows-x64-mingw/makeMakefile.pl O.windows-x64-mingw ../..
C:/Strawberry/c/bin/make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
    T_A=windows-x64-mingw install
make[3]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64-mingw'
make[3]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64-mingw'
make[2]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure'
C:/Strawberry/c/bin/make -C ./pcocam2App install
make[2]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App'
C:/Strawberry/c/bin/make -C ./src install
make[3]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src'
perl -CSD C:/epics/base-3.15.7/bin/windows-x64-mingw/makeMakefile.pl O.windows-x64-mingw ../../..
C:/Strawberry/c/bin/make -C O.windows-x64-mingw -f ../Makefile TOP=../../.. \
make[4]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64-mingw'
g++            /O2 /wd4290   -D_MINGW     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common
 -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include      -I/epics/modules/asyn-
R4-37/include   -I/epics/modules/calc-R3-7-3/include   -I/epics/modules/sscan-R2-11-3/include   -I/epics/modules/busy-R1
-7-2/include   -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF PcoApi.d -MT PcoApi.obj ../PcoApi.cp
p
g++: error: /O2: No such file or directory
g++: error: /wd4290: No such file or directory
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF NdArrayRef.d -MT NdArrayRef.obj ../N
dArrayRef.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF ADDriverEx.d -MT ADDriverEx.obj ../A
DDriverEx.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF AsynParam.d -MT AsynParam.obj ../Asy
nParam.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF StringParam.d -MT StringParam.obj ..
/StringParam.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF DoubleParam.d -MT DoubleParam.obj ..
/DoubleParam.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF IntegerParam.d -MT IntegerParam.obj
../IntegerParam.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF FreeLock.d -MT FreeLock.obj ../FreeL
ock.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF TakeLock.d -MT TakeLock.obj ../TakeL
ock.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF SimulationApi.d -MT SimulationApi.ob
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF PcoException.d -MT PcoException.obj
../PcoException.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF PerformanceMonitor.d -MT Performance
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF SocketProtocol.d -MT SocketProtocol.
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF GangServerConfig.d -MT GangServerCon
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF GangMemberConfig.d -MT GangMemberCon
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF GangConfig.d -MT GangConfig.obj ../G
angConfig.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF GangConnection.d -MT GangConnection.
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF GangClient.d -MT GangClient.obj ../G
angClient.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF GangServer.d -MT GangServer.obj ../G
angServer.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF TraceStream.d -MT TraceStream.obj ..
/TraceStream.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF StateMachine.d -MT StateMachine.obj
../StateMachine.cpp
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF AsynException.d -MT AsynException.ob
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF NDArrayException.d -MT NDArrayExcept
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF DllApi.d -MT DllApi.obj ../DllApi.cp
p
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/     -MM -MF Pco.d -MT Pco.obj ../Pco.cpp
mkdir ../../../dbd
-3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include     -I../include/    -o Pco.obj -c ../Pco.cpp
make[4]: *** [/epics/base-3.15.7/configure/RULES_BUILD:240: Pco.obj] Error 1
make[4]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64-mingw'
make[3]: *** [/epics/base-3.15.7/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[3]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src'
make[2]: *** [/epics/base-3.15.7/configure/RULES_DIRS:84: src.install] Error 2
make[2]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App'
make[1]: *** [/epics/base-3.15.7/configure/RULES_DIRS:84: pcocam2App.install] Error 2
make[1]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin'
make: *** [/epics/base-3.15.7/configure/RULES_DIRS:84: /epics/modules/areaDetector-R3-8/ADPcoWin.install] Error 2
PS C:\epics\modules\areaDetector-R3-8>
It seems there are no "/O2" "/wd4290" directories... Did I missed something in the config files?
My CONFIG_SITE.local (located in: C:\epics\modules\areaDetector-R3-8\configure) looks like this:
# To build the IOC applications set BUILD_IOCS to YES
# Otherwise set it to NO
BUILD_IOCS=YES
# To build areaDetector so that it only depends on libCom and asyn set the following flag
#EPICS_LIBCOM_ONLY=YES
# Configure which 3rd party libraries to use and where to find them.
# For each library XXX the following definitions are used:
# WITH_XXX      Build the plugins and drivers that require this library.
#               Build the source code for this library in ADSupport if XXX_EXTERNAL=NO.
# XXX_EXTERNAL  If NO then build the source code for this library in ADSupport.
# XXX_INCLUDE   If XXX_EXTERNAL=YES then this is the path to the include files for XXX.
#               However, if XXX is a system library whose include files are in a
#               standard include search path then do not define XXX_INCLUDE.
# XXX_LIB       If XXX_EXTERNAL=YES then this is the path to the library files for XXX.
#               However, if XXX is a system library whose library files in a
#               standard library search path then do not define XXX_LIB.
# The exception to the above is XML2.
# As of ADCORE R3-0 libxml2 is required for ADCore so WITH_XML2 is not supported
# but the other XML2 flags are supported.
# The default defined here is appropriate for most Linux systems.
# BOOST is required for the ADCore/pluginTests unit tests
WITH_BOOST     = NO
BOOST_EXTERNAL = YES
#BOOST_LIB     =
#BOOST_INCLUDE =
# Uncomment this line if you want to use STATIC Linking when building
# ADCore/pluginTests unit tests.
#BOOST_USE_STATIC_LINK=YES
# EPICS PVA is required for NDPluginPva, pvaDriver, and qsrv
WITH_PVA  = NO
# WITH_QSRV controls whether IOCs are built with support for qsrv.
# This is separate from WITH_PVA to allow PVA to be enabled but QSRV to be disabled.
# This is needed on 3.14.12 where PVA is supported but QSRV is not.
# Note that if WITH_QSRV=YES then WITH_PVA must also be YES
WITH_QSRV = NO
# BLOSC is required to use the blosc compressors in the HDF5 plugin
WITH_BLOSC     = NO
BLOSC_EXTERNAL = NO
#BLOSC_INCLUDE =
#BLOSC_LIB     =
# BITSHUFFLE is required to use the bitshuffle/LZ4 decompressors in the ADEiger driver
# It can also be used to generate shareable libraries for the HDF5 compressor/decompressor
WITH_BITSHUFFLE     = NO
BITSHUFFLE_EXTERNAL = NO
# GraphicsMagick is required for NDFileMagick and the URL driver.
WITH_GRAPHICSMAGICK     = NO
GRAPHICSMAGICK_EXTERNAL = NO
# GraphicsMagick defines many global symbols, and one of these (SetImage) conflicts with a symbol
# in the Andor vendor library.  GraphickMagick provides a solution by allowing all external library
# symbols to be prefixed with "Gm".  Enable using this by default.  However, if a system library
# is used it may not be built with this option so this line should be commented out.
GRAPHICSMAGICK_PREFIX_SYMBOLS = NO
#GRAPHICSMAGICK_INCLUDE =
#GRAPHICSMAGICK_LIB     =
# HDF5 is required for the NDFileHDF5 and NDFileNexus plugins
WITH_HDF5     = NO
HDF5_EXTERNAL = NO
#HDF5_INCLUDE =
#HDF5_LIB     =
# JPEG is required for the NDFileJPEG and NDFileTIFF plugins
WITH_JPEG     = YES
JPEG_EXTERNAL = NO
#JPEG_INCLUDE =
#JPEG_LIB     =
# JPEG is required for the NDFileNetCDF plugin
WITH_NETCDF     = NO
NETCDF_EXTERNAL = NO
#NETCDF_INCLUDE =
#NETCDF_LIB     =
# NEXUS is required for the NDFileNexus plugin
WITH_NEXUS     = NO
NEXUS_EXTERNAL = NO
#NEXUS_INCLUDE =
#NEXUS_LIB     =
# OPENCV is required for the ADPluginEdge plugin
WITH_OPENCV     = NO
OPENCV_EXTERNAL = YES
#OPENCV_INCLUDE =
#OPENCV_LIB     =
# SZIP is required for the NDFileHDF5 and NDFileNexus plugins.
# This may be optional in the future.
WITH_SZIP     = NO
SZIP_EXTERNAL = NO
#SZIP_INCLUDE =
#SZIP_LIB     =
# TIFF is required for the NDFileTIFF plugin.
WITH_TIFF     = YES
TIFF_EXTERNAL = NO
#TIFF_INCLUDE =
#TIFF_LIB     =
# XML2 is required for ADCore so there is no WITH_XML2.
XML2_EXTERNAL = NO
#XML2_INCLUDE =
#XML2_LIB     =
# ZLIB is required for the NDFileHDF5 and NDFileNexus plugins.
WITH_ZLIB     = NO
ZLIB_EXTERNAL = NO
#ZLIB_INCLUDE =
#ZLIB_LIB     =
# ARAVIS is required for aravisGigE and ADAravis
# Only available on Linux
#ARAVIS_LIB      = /usr/local/lib
#ARAVIS_INCLUDE  = /usr/local/include/aravis-0.8
# Location of GLIB include files and libraries.  This is needed for aravis.
# Our system has include files for glib-2.0 in 2 different places
#GLIB_INCLUDE = /usr/include/glib-2.0 /usr/lib64/glib-2.0/include
#glib-2.0_DIR = /usr/lib64
# The definitions above can be overridden in the following files.
# The files are searched in this order, with the last definition being used.
#    CONFIG_SITE.local.$(OS_CLASS)
#    CONFIG_SITE.local.$(EPICS_HOST_ARCH)
#    CONFIG_SITE.local.$(EPICS_HOST_ARCH).$(T_A)
Are there any libraries that ADPcoWin uses which I set to no?
Thanks for the support!
Michael
Von: Sintschuk, Michael
Gesendet: Mittwoch, 11. Dezember 2019 10:01:58
An: Mark Rivers
Cc: [email protected]<mailto:[email protected]>
Betreff: AW: pco Camera USB and IEEE interface
Hey Mark, hey Diego,
thanks for the help! I try the ADPcoWin driver. On github it says that the interface is CameraLink:
https://github.com/areaDetector/ADPcoWin
But if you say it works with any interface (what about IEEE only?), I will try it on a Windows7 64bit system.
Michael
Von: Mark Rivers <[email protected]<mailto:[email protected]>>
Gesendet: Dienstag, 10. Dezember 2019 19:42:53
Another possibility is the ADPcoWin driver. This driver uses the PCO SDK so it should work with any camera interface, GigE or CameraLink. It only runs on Windows.
Sent from my iPhone
On Dec 10, 2019, at 2:38 AM, Sintschuk, Michael via Tech-talk <[email protected]<mailto:[email protected]<mailto:[email protected]%3cmailto:[email protected]>>> wrote:
Hello,
I have a pco.1600 camera with a USB/Ethernet interface and a pco.4000 camera with a IEEE interface. Is there a possibility for me to communicate with these cameras via an IOC?
The AreaDetector Driver I found is intended for Cameralink-based communication:
https://github.com/areaDetector/ADPCO
Best regards
Michael Sintschuk
Michael Sintschuk
Bundesanstalt f?r Materialforschung und -pr?fung (BAM)
P: +49 30 8104-5736 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Lichterfelde)
AW: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
RE: pco Camera USB and IEEE interface Mark Rivers via Tech-talk
Re: pco Camera USB and IEEE interface Mark Rivers via Tech-talk
Prev: RE: Beckhoff PLC support; Motion control Artur Piscalov via Tech-talk
Next: RE: Beckhoff PLC support; Motion control Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Prev: AW: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
Next: AW: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
