Subject: RE:Support for Cryocon 22C
From: "Ruiz-Rodriguez, Mariano M. via Tech-talk" <[email protected]>
Date: Fri, 28 Feb 2020 13:22:33 +0000
Hi!
We have the cryocon model 18. The 22C and 18 both support SCPI commands.
https://www.cryocon.com/Model18C/M18CUMTop.pdf
https://www.cryocon.com/M22C/M22CUMtop.pdf
We don’t do much with the crycon 18. We are reading the IDN and the temperatures from several sensors using the input command.
Protocol
Terminator = CR;
LockTimeout = 10000;
ReplyTimeout = 500;
ReadTimeout = 500;
WriteTimeout = 500;
#Read Identification
IDN {
  out "*IDN?";
  in "%39c";
# read temperatures from cryostream
Temp1 {
  out "input? a";
  in "%g";
Database for one sensor and IDN. That IDN can probably just be PINI
record(stringin, "$(S):$(TA):$(DN):CryoconIDN")
        field(DESC, "Cryocon Identification")
        field(DTYP, "stream")
        field(INP, "@test.proto IDN $(port)")
        field(PINI, "YES")
record(ai, "$(S):$(TA):$(DN):CryoconA")
        field(DESC, "Cryocon Temperature")
        field(INP, "@test.proto Temp1 $(port)")
        field(SCAN, "1 second")
        field(EGU,"K")
        field(PREC,"2")
        field(MDEL,"0.005")
        field(ADEL,"0.05")
        field(HIHI, "$(HA)")
        field(HHSV, "MAJOR")
        info (archive, "monitor, 00:00:01, VAL")
        info(autosaveFields, "HIHI")
Substitutions for one crycon. HA HB and so on are the HIHI fields.
file cryocon.db {
   { S=BL16B, TA=SE, DN=TC1, port=CryoconPort1, HA=100, HB=100, HC=100, HD=100, HE= 100, HF=100, HG=100, HH=100 }
St.cmd file. We communicate directly to it using the TCP IP interface to port 5000. It has a webserver for configuration and info.
asynSetAutoConnectTimeout(1.0)
drvAsynIPPortConfigure( "CryoconPort1", "10.111.33.11:5000 tcp", 0, 0, 0 )
Mariano
From: Tech-talk <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Thursday, February 27, 2020 1:00 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Tech-talk Digest, Vol 14, Issue 130
Send Tech-talk mailing list submissions to
        [email protected]
To subscribe or unsubscribe via the World Wide Web, visit
        https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
        [email protected]
You can reach the person managing the list at
        [email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. Re: Support for Cryocon 22C (Cobb, Tom (DLSLtd,RAL,LSCI))
Message: 1
Date: Thu, 27 Feb 2020 09:31:32 +0000
From: "Cobb, Tom (DLSLtd,RAL,LSCI)" <[email protected]>
To: tech-talk <[email protected]>, Mark Rivers
        <[email protected]>
Subject: Re: Support for Cryocon 22C
Message-ID:
        <DB6PR0101MB2533A844D34AF785BD2A2C1FD6EB0@DB6PR0101MB2533.eurprd01.prod.exchangelabs.com>
Content-Type: text/plain; charset="us-ascii"
Hi Mark,
I'm not sure of the history of the modules, but I found support for both the M14 and the M32 in our repositories and pushed them to github:
https://github.com/dls-controls/CryoconM14
https://github.com/dls-controls/CryoconM32
Tom
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 26 February 2020 23:50
Subject: Support for Cryocon 22C
Does anyone have EPICS support for the Cryocon 22C temperature controller?
Some of their more advanced units have an EPICS server built-in, but the 22C does not.
I see Pete Owens at Diamond listed as having StreamDevice support for the model 14.  The model 14 StreamDevice support would probably be a good place to start if the 22C is not directly supported.  It that on Github?
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20200227/f127ffb5/attachment.html>
Subject: Digest Footer
Tech-talk mailing list [email protected]
End of Tech-talk Digest, Vol 14, Issue 130
Prev: Re: firewalld configuration for EPICS? Ralph Lange via Tech-talk
Next: RE: Beckhoff PLC support; Motion control Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: Support for Cryocon 22C Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: RE: Oxford IC101 support [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
