1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: defining a path of PVA for EPICS base 3.x
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: "matic.pogacnik at cosylab.com" <matic.pogacnik at cosylab.com>
Cc: Jong Woo Kim <Jong.Woo.Kim at asu.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 3 Mar 2020 19:40:01 +0000
If you’re willing to upgrade to EPICS 7 recent versions of the PVA modules included with it are significantly more robust and reliable than the stand-alone versions that worked with Base 3.x, and there’s less work setting them up. I would recommend upgrading, especially for recent AreaDetector versions (which might not build with the older V4 code anyway).
- Andrew
On Mar 3, 2020, at 1:22 PM, Matic Pogacnik via Tech-talk <tech-talk at aps.anl.gov> wrote:
EPICS V3 doesn’t include V4 modules. They must be downloaded separately from http://epics-pvdata.sourceforge.net/index.html (https://sourceforge.net/projects/epics-pvdata/files/ )
Best regards,
Matic
----- Original Message -----
From: "Jong Woo Kim via Tech-talk" <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Sent: Tuesday, March 3, 2020 7:57:03 PM
Subject: defining a path of PVA for EPICS base 3.x
I am using the following versions.
EPICS base-3.15.6
asyn4-37
areaDetector-R3-9
ADCore-R3-9
There is a way to define the path of 'PVA' for those who use prior to EPICS base 7.
The following shows an example for EPICS V4. I couldn't find a corresponding folder or files in EPICS base-3.15.6.
Do I have to upgrade?
_________________________________________________________________________
# If CONFIG_SITE.local defines WITH_PVA=YES and EPICS_BASE is prior to 7.0 then define the path here
# If using EPICS_BASE 7.0 or later the PVA files are in base itself and no additional definitions are needed.
#PVA=/corvette/usr/local/epics-devel/epicsV4/EPICS-CPP-4.6.0
# PVA modules
# For versions prior to EPICS base 7.0 use this
#PVCOMMON=$(PVA)/pvCommonCPP
#PVACCESS=$(PVA)/pvAccessCPP
#PVDATA=$(PVA)/pvDataCPP
#PVDATABASE=$(PVA)/pvDatabaseCPP
#NORMATIVETYPES=$(PVA)/normativeTypesCPP
-include $(AREA_DETECTOR)/configure/RELEASE_LIBS.local.$(EPICS_HOST_ARCH)
Complexity comes for free, Simplicity you have to work for.
defining a path of PVA for EPICS base 3.x Jong Woo Kim via Tech-talk
Re: defining a path of PVA for EPICS base 3.x Matic Pogacnik via Tech-talk
Prev: Re: defining a path of PVA for EPICS base 3.x Matic Pogacnik via Tech-talk
Next: areaDetector ADViewers R1-6 released Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Next: Re: defining a path of PVA for EPICS base 3.x Michael Davidsaver via Tech-talk
ANJ, 04 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
