1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: areaDetector ADViewers R1-6 released
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 3 Mar 2020 22:37:39 +0000
Folks,
ADViewers R1-6 is now available.
This is from the release notes:
### New Python viewer, PT_NTNDA_Viewer.  It was written by Marty Kraimer.
This viewer has the following features:
* Supports compressed NDArrays using any of the codecs in NDPluginCodec.
* Supports all NDArray data types and color modes.
* Allows zooming by defining the subregion with a mouse.
* Allows changing the window size.
* Allows changing the lower and upper display intensities with sliders.
* Supports pvAccess only, does not support Channel Access.
* Works with both the p4p and pvaPy Python bindings for pvAccess.
  - p4p works on Windows, Linux, and Mac.
  - pvapy works only on Linux and Mac.
### Documentation improvements
* Broke up the documentation into smaller documents to make it easier to read.
The documentation for the new Python viewer is here:
https://areadetector.github.io/master/ADViewers/PY_NTNDA_Viewer.html
The code is on Github here:
https://github.com/areaDetector/ADViewers
Prev: Re: defining a path of PVA for EPICS base 3.x Johnson, Andrew N. via Tech-talk
Next: errors in /ADCore/ADApp/pluginTests when building areaDetector-R3-9 Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: defining a path of PVA for EPICS base 3.x Michael Davidsaver via Tech-talk
ANJ, 04 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
