1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: RE: Asyn support for GPIB-ENET
From: Kathryn Baker - UKRI STFC via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 4 Mar 2020 14:23:47 +0000
The NI boxes are most certainly not happy with VXI-11s – we haven’t been using it with the /1000 yet, but with the /100 that is used frequently on one of the instruments here we actually have an NI VISA asyn driver that is available here: https://github.com/ISISComputingGroup/EPICS-VISA
We’re likely to be using it with a /1000 later this year, but it shouldn’t need much in the way of correcting for this.
Kathryn
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: 04 March 2020 14:10
<snip>
Another issue is that it looks like you are trying to use the drvAsynIPPort driver to talk to the NI GPIB-ENET/1000.  It don’t think that will work.  Most Ethernet to GPIB devices are VXI-11 compliant, and so can use the EPICS VXI-11 driver.  But the NI GPIB-ENET is not VXI-11 compliant, it uses a National Instruments proprietary protocol.
There was a tech-talk thread that discussed this several years ago.  You should look at all of the messages in this thread.
https://epics.anl.gov/tech-talk/2017/msg01127.php
[Baker, Kathryn (STFC,RAL,ISIS)] <snip>
RE: Asyn support for GPIB-ENET Mark Rivers via Tech-talk
Prev: RE: Asyn support for GPIB-ENET Mark Rivers via Tech-talk
Next: areaDetector ADViewers R1-6-1 released Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Next: Re:RE: Asyn support for GPIB-ENET 杨栋亮 via Tech-talk
ANJ, 05 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
