Subject: RE: Asyn support for GPIB-ENET
To: '杨栋亮' <[email protected]>
Date: Wed, 4 Mar 2020 14:10:11 +0000
I think the main problem is that this line:
serialTest_DBD += drvAsynIPPort.dbd
needs to be changed to:
serialTest_DBD += asyn.dbd drvAsynIPPort.dbd
asyn.dbd is where the asynRecord and lots of other things are defined.
Another issue is that it looks like you are trying to use the drvAsynIPPort driver to talk to the NI GPIB-ENET/1000.  It don’t think that will work.  Most Ethernet to GPIB devices are VXI-11 compliant, and so can use the EPICS VXI-11 driver.  But the NI GPIB-ENET is not VXI-11 compliant, it uses a National Instruments proprietary protocol.
There was a tech-talk thread that discussed this several years ago.  You should look at all of the messages in this thread.
https://epics.anl.gov/tech-talk/2017/msg01127.php
The final message was an offer to contribute a new driver for the National Instruments VISA library, but as far as I know that never happened. We could follow up on that if it is important for you.
Sent: Wednesday, March 4, 2020 7:13 AM
Subject: Asyn support for GPIB-ENET
Hi Mark,
I’m trying to build asyn support on windows-x64 to use with GPIB over Ethernet (NI GPIB-ENET/1000).
I have installed the NI’driver for GPIB-ENET/1000. It works well.
  1. Create a new application
    mkdir serialTest
    cd serialTest
    makeBaseApp.pl -t ioc serialTest
    makeBaseApp.pl -i -t ioc serialTest
  2. Add ASYN support.
    Edit configure/RELEASE.
    ASYN=$(SUPPORT)/asyn-R4-37
    Edit serialTestApp/src/Makefile and add two lines.
    serialTest_LIBS += asyn
    Edit serialTestApp/Db/Makefile and add a line:
    DB_INSTALLS += $(ASYN)/db/asynRecord.db
    Edit iocBoot/iocSerialTest/st.cmd.
    #!../../bin/windows-x64/serialTest
    < envPaths
    cd ${TOP}
    dbLoadDatabase("dbd/serialTest.dbd",0,0)
    serialTest_registerRecordDeviceDriver(pdbbase)
    ## Configure devices
    drvAsynIPPortConfigure("L0","192.168.21.98:5000",0,0,0)
    ## Load record instances
    dbLoadRecords("db/asynRecord.db","P=norum:,R=asyn,PORT=L0,ADDR=27,IMAX=100,OMAX=100")
    cd ${TOP}/iocBoot/${IOC}
    iocInit()
  3. Build the application (run gmake from the application top directory).
    No errors.
  4. Start the IOC
    cd iocBoot/iocserialTest
    ../../bin/windows-x64/serialTest st.cmd
The following error occurred:
dbLoadRecords(“db/asynRecord.db”,...............)
Record “norum:asyn” is of unknown type “asyn”
This problem may be because I didn't add the asyn module correctly.
But I don't know how to modify it.
Could you give me any advice?
Dongliang
RE: Asyn support for GPIB-ENET Kathryn Baker - UKRI STFC via Tech-talk
Re:RE: Asyn support for GPIB-ENET 杨栋亮 via Tech-talk
Prev: Re: pco Camera USB and IEEE interface Mark Rivers via Tech-talk
Next: RE: Asyn support for GPIB-ENET Kathryn Baker - UKRI STFC via Tech-talk
Prev: Re: Quantalux sCMOS camera Mark Rivers via Tech-talk
