On 03/05, Christoph Schroeder wrote:
> yep that seems to be the same problem. I read this thread and there were
> some suggestions, but it seem that none of them made it into a real feature.
> Did you find an elegant workaround? I created a rather dirty solution
> with a seq record using the DLY field.
I don't think so, but I can't remember for sure. I probably added an
epicsThreadSleep, changed the links to not be CA links, or restructured
the record instances to work around the problem.
Lewis
- Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
- CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
- Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
- Re: CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
<2020>
2025
<2020>
2025
