Subject: Re: CA output links not working with PINI=YES?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 5 Mar 2020 17:25:01 +0100
When an IOC boots, it starts its components in a specific order.
At the time when PINI=YES records are being processed, Channel Access is simply not fully up yet.
Note that for a while PINI has been a menu with different options. Maybe you can get your record processed in a later stage that way.
Cheers,
~Ralph
Re: CA output links not working with PINI=YES? Mark Rivers via Tech-talk
Re: CA output links not working with PINI=YES? Benjamin Franksen via Tech-talk
CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Re: CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Prev: Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Next: SIOL field buffer size? Daykin, Evan via Tech-talk
Next: Re: CA output links not working with PINI=YES? Mark Rivers via Tech-talk
