Subject: Re: CA output links not working with PINI=YES?
To: Ralph Lange <[email protected]>
Date: Thu, 5 Mar 2020 18:03:12 +0000
This is menuPini.dbd
menu(menuPini) {
        choice(menuPiniNO,"NO")
        choice(menuPiniYES,"YES")
        choice(menuPiniRUN,"RUN")
        choice(menuPiniRUNNING,"RUNNING")
        choice(menuPiniPAUSE,"PAUSE")
        choice(menuPiniPAUSED,"PAUSED")
Where is this documented?  The 3.15.7 and 3.16.2 Application Developer's Guide only says this about PINI:
7.4.10 Initial Processing
initialProcess processes all records that have PINI set to YES. initHookAfterInitialProcess is announced.
What is the difference between PINI=YES and PINI=RUNNING?  Is there anything in that menu that happens later than YES during iocInit?
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk <[email protected]>
Sent: Thursday, March 5, 2020 10:25 AM
To: EPICS Tech Talk
When an IOC boots, it starts its components in a specific order.
At the time when PINI=YES records are being processed, Channel Access is simply not fully up yet.
Note that for a while PINI has been a menu with different options. Maybe you can get your record processed in a later stage that way.
Cheers,
~Ralph
Re: CA output links not working with PINI=YES? Johnson, Andrew N. via Tech-talk
CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Re: CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
Prev: SIOL field buffer size? Daykin, Evan via Tech-talk
Next: Re: CA output links not working with PINI=YES? Benjamin Franksen via Tech-talk
Prev: Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
Next: Re: CA output links not working with PINI=YES? Johnson, Andrew N. via Tech-talk
