Subject: ADUrl Segfault on initialization
Date: Tue, 10 Mar 2020 14:14:12 +0000
Hello all –
We are having an issue with the ADUrl module: it crashes with a segfault on initialization. It seems to build find, but it does not work when we try to actually initialize it.
We are running a startup script which starts as follows (note that at ESS we are using a similar architecture to PSI i.e. a require module which dynamically loads shared libraries; moreover, we are building our modules within Conda):
require adurl
require busy
require sscan
require calc
epicsEnvSet("IOC",         "iocURLTest")
epicsEnvSet("TOP",         ".")
epicsEnvSet("PREFIX", "URL1:")
epicsEnvSet("CALC",        "/home/iocuser/e3/e3-calc")
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES","64000000")
### The port name for the detector
epicsEnvSet("PORT",   "URL1")
### Queue size
epicsEnvSet("QSIZE",  "5")
### The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "2048")
### The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "1556")
### The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
### The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
### The search path for database files
# epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
### Define NELEMENTS
epicsEnvSet("NELEMENTS", "12582912")
# Create a URL driver
# URLDriverConfig(const char *portName, int maxBuffers, size_t maxMemory,
#                 int priority, int stackSize)
URLDriverConfig("$(PORT)", 0, 0)
Etc.
At this point, the IOC crashes with the following error. Note that iocsh.bash is essentially just a wrapper for softIocPVA.
../_h_env/bin/iocsh.bash: line 116:  3062 Segmentation fault      (core dumped) softIoc${_PVA_} -D ${EPICS_BASE}/dbd/softIoc${_PVA_}.dbd "${IOC_STARTUP}" 2>&1
The full output from the startup is the following:
registerChannelProviderLocal firstTime true
# Start at "2020-W11-Mar10-1341-15-UTC"
# Version information:
# European Spallation Source ERIC : iocsh.bash (3.1.0-PID-3039)
# --->--> snip -->-->
# Please Use Version and other environment variables
# in order to report or debug this shell
# HOSTDISPLAY=""
# WINDOWID=""
# PWD="/opt/conda/conda-bld/debug_1583846564892/work"
# USER="conda"
# LOGNAME="conda"
# EPICS_HOST_ARCH="linux-x86_64"
# EPICS_BASE="/opt/conda/conda-bld/debug_1583846564892/_h_env/base"
# E3_REQUIRE_NAME="require"
# E3_REQUIRE_VERSION="3.1.0"
# E3_REQUIRE_LOCATION="/opt/conda/conda-bld/debug_1583846564892/_h_env/modules/require/3.1.0"
# E3_REQUIRE_BIN="/opt/conda/conda-bld/debug_1583846564892/_h_env/bin"
# E3_REQUIRE_DB="/opt/conda/conda-bld/debug_1583846564892/_h_env/modules/require/3.1.0/db"
# E3_REQUIRE_DBD="/opt/conda/conda-bld/debug_1583846564892/_h_env/modules/require/3.1.0/dbd"
# E3_REQUIRE_INC="/opt/conda/conda-bld/debug_1583846564892/_h_env/modules/require/3.1.0/include"
# E3_REQUIRE_LIB="/opt/conda/conda-bld/debug_1583846564892/_h_env/modules/require/3.1.0/lib"
# EPICS_DRIVER_PATH="/opt/conda/conda-bld/debug_1583846564892/_h_env/modules"
# EPICS_CA_AUTO_ADDR_LIST=""
# EPICS_CA_ADDR_LIST=""
# PATH="/opt/conda/conda-bld/debug_1583846564892/_build_env/bin:/opt/conda/conda-bld/debug_1583846564892/_h_env/base/bin/linux-x86_64:/opt/conda/conda-bld/debug_1583846564892/_build_env:/opt/conda/conda-bld/debug_1583846564892/_build_env/bin:/opt/conda/conda-bld/debug_1583846564892/_h_env:/opt/conda/conda-bld/debug_1583846564892/_h_env/bin:/opt/conda/conda-bld/debug_1583846564892/_h_env/bin:/opt/conda/bin:/opt/conda/condabin:/opt/conda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Set REQUIRE_IOC for its internal PVs
epicsEnvSet REQUIRE_IOC "REQMOD:26E3270A7C7F-3055"
# Set E3_IOCSH_TOP for the absolute path where iocsh.bash is executed.
epicsEnvSet E3_IOCSH_TOP "/opt/conda/conda-bld/debug_1583846564892/work"
# Load require module, which has the version 3.1.0
dlload /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/require/3.1.0/lib/linux-x86_64/librequire.so
dbLoadDatabase /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/require/3.1.0/dbd/require.dbd
require_registerRecordDeviceDriver
Loading module info records for require
# Set E3_CMD_TOP for the absolute path where st.ADURL_test.cmd exists
epicsEnvSet E3_CMD_TOP "/opt/conda/conda-bld/debug_1583846564892/work/cmds"
iocshLoad 'cmds/st.ADURL_test.cmd',''
require adurl
Module adurl version 2.2.0 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adurl/2.2.0/
Module adurl depends on adcore 3.7.0
Module adcore version 3.7.0 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adcore/3.7.0/
Module adcore depends on adsupport 1.9.0
Module adsupport version 1.9.0 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adsupport/1.9.0/
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adsupport/1.9.0/lib/linux-x86_64/libadsupport.so
Loaded adsupport version 1.9.0
adsupport has no dbd file
Loading module info records for adsupport
Module adcore depends on asyn 4.36.0
Module asyn version 4.36.0 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/asyn/4.36.0/
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/asyn/4.36.0/lib/linux-x86_64/libasyn.so
Loaded asyn version 4.36.0
Loading dbd file /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/asyn/4.36.0/dbd/asyn.dbd
Calling function asyn_registerRecordDeviceDriver
Loading module info records for asyn
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adcore/3.7.0/lib/linux-x86_64/libadcore.so
Loaded adcore version 3.7.0
Loading dbd file /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adcore/3.7.0/dbd/adcore.dbd
Calling function adcore_registerRecordDeviceDriver
Loading module info records for adcore
Module adurl depends on asyn 4.36.0
Module asyn version 4.36.0 already loaded
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adurl/2.2.0/lib/linux-x86_64/libadurl.so
Loaded adurl version 2.2.0
Loading dbd file /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/adurl/2.2.0/dbd/adurl.dbd
Calling function adurl_registerRecordDeviceDriver
Loading module info records for adurl
require busy
Module busy version 1.7.0 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/busy/1.7.0/
Module busy depends on asyn 4.36.0
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/busy/1.7.0/lib/linux-x86_64/libbusy.so
Loaded busy version 1.7.0
Loading dbd file /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/busy/1.7.0/dbd/busy.dbd
Calling function busy_registerRecordDeviceDriver
Loading module info records for busy
require sscan
Module sscan version 2.11.2 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/sscan/2.11.2/
Module sscan depends on seq 2.2.7
Module seq version 2.2.7 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/seq/2.2.7/
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/seq/2.2.7/lib/linux-x86_64/libseq.so
Loaded seq version 2.2.7
seq has no dbd file
Loading module info records for seq
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/sscan/2.11.2/lib/linux-x86_64/libsscan.so
Loaded sscan version 2.11.2
Loading dbd file /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/sscan/2.11.2/dbd/sscan.dbd
Calling function sscan_registerRecordDeviceDriver
Loading module info records for sscan
require calc
Module calc version 3.7.1 found in /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/calc/3.7.1/
Module calc depends on seq 2.2.7
Module seq version 2.2.7 already loaded
Module calc depends on sscan 2.11.2
Module sscan version 2.11.2 already loaded
Loading library /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/calc/3.7.1/lib/linux-x86_64/libcalc.so
Loaded calc version 3.7.1
Loading dbd file /opt/conda/conda-bld/debug_1583846564892/_h_env/modules/calc/3.7.1/dbd/calc.dbd
Calling function calc_registerRecordDeviceDriver
Loading module info records for calc
### Queue size
URLDriverConfig("URL1", 0, 0)
If I build the ADUrl library with the -ggdb flag, then I can run a backtrace and I find the following:
Thread 1 "softIocPVA" received signal SIGSEGV, Segmentation fault.
0x00007ff49c608cc0 in pthread_mutex_lock () from /lib64/libpthread.so.0
(gdb) bt
#0  0x00007ff49c608cc0 in pthread_mutex_lock () from /lib64/libpthread.so.0
#1  0x00007ff49847db27 in GmLockSemaphoreInfo () from /opt/conda/conda-bld/debug_1583846564892/_h_env/lib/libGraphicsMagick.so.3
#2  0x00007ff49847a8ff in GmGetMagickResourceLimit () from /opt/conda/conda-bld/debug_1583846564892/_h_env/lib/libGraphicsMagick.so.3
#3  0x00007ff49845ae09 in GmGetCacheInfo () from /opt/conda/conda-bld/debug_1583846564892/_h_env/lib/libGraphicsMagick.so.3
#4  0x00007ff4984388bd in GmAllocateImage () from /opt/conda/conda-bld/debug_1583846564892/_h_env/lib/libGraphicsMagick.so.3
#5  0x00007ff498379c5a in Magick::ImageRef::ImageRef() () from /opt/conda/conda-bld/debug_1583846564892/_h_env/lib/libGraphicsMagick++.so.12
#6  0x00007ff49836f5fe in Magick::Image::Image() () from /opt/conda/conda-bld/debug_1583846564892/_h_env/lib/libGraphicsMagick++.so.12
#7  0x00007ff49d5a55ac in URLDriver::URLDriver (this=0x559b447799f0, portName=<optimized out>, maxBuffers=<optimized out>, maxMemory=<optimized out>, priority=<optimized out>,
    stackSize=<optimized out>) at ../urlApp/src/URLDriver.cpp:387
#8  0x00007ff49d5a57e1 in URLDriverConfig (portName=0x559b4479e800 "URL1", maxBuffers=0, maxMemory=0, priority=0, stackSize=0) at ../urlApp/src/URLDriver.cpp:445
#9  0x00007ff49d093a88 in iocshBody () from /opt/conda/conda-bld/debug_1583846564892/_h_env/base/bin/linux-x86_64/../../lib/linux-x86_64/libCom.so.3.17.6
#10 0x00007ff49d093a88 in iocshBody () from /opt/conda/conda-bld/debug_1583846564892/_h_env/base/bin/linux-x86_64/../../lib/linux-x86_64/libCom.so.3.17.6
#11 0x0000559b434d04e1 in main ()
The version of ADUrl we are trying to build and run is 2.2.0. We are including graphicsmagick 1.3.33, and we are building for base 7.0.3.1 with asyn 4.36.0. The crash seems to happen at the call to the super constructor ADDriver(…), although I admit that I am a bit confused by that: as said, the line in question is the call to the super-class constructor. I am not sure how we end up in Magick::Image::Image().
Any help would be greatly appreciated.
Cheers,
Simon Rose
Re: ADUrl Segfault on initialization Mark Rivers via Tech-talk
Prev: Re: Load or reload databases after IOC initialization bob dalesio via Tech-talk
Next: Re: ADUrl Segfault on initialization Mark Rivers via Tech-talk
