1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: camserver/NDStdArray latency mystery
From: John Dobbins via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 10 Mar 2020 16:38:25 +0000
First, apologies because this is about two old versions of areaDetector.
We have two Pilatus IOCs. One is areaDetector R1-9, Base 3.14.8 and one is R2-2 Base 3.14.12.4
Taking single images on the R2-2 version there is a latency of one image in the NDStdArray which is sent to Channel Access.  The image is also being written to a file and that receives the latest image however the file is being written by camserver (tvx-7.3.13-121212).  Note that these are manually triggered images, rate is not an issue.
It is possible that the IOC is received a delayed image from camserver.
How can I determine if the latency is between camserver/IOC  or  within IOC?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
RE: camserver/NDStdArray latency mystery Mark Rivers via Tech-talk
Prev: RE: pco Camera USB and IEEE interface Mark Rivers via Tech-talk
Next: RE: camserver/NDStdArray latency mystery Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: ADUrl Segfault on initialization Mark Rivers via Tech-talk
ANJ, 10 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
