1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Real-time IOC and systemd
From: Benjamin Franksen via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 13 Mar 2020 21:22:31 +0100
Am 12.03.20 um 13:06 schrieb Konrad, Martin:
>  In my opinion the zoo of traditional command-line tools isn't
> doing that much better, though.
YMMV, but IME it does /a lot/ better. The documentation of each fits on
a screen or two, and you can learn about each one as you go along. You
invoke them exactly if and when you have an actual need. Each has a
single dedicated purpose and it is easy to combine them and reason about
their interaction (if any). Their small code size means they are much
more easily reviewed for correctness and security. Their versatility
means they receive a lot more test coverage as people can and do use
them in a variety of situations.
> On top of that there is the usual
> question: which of these tools are still up-to-date/recommended?
This is just FUD. These utilities are all part of the standard
util-linux package and won't go away; some of them, like unshare, are
even quite new.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Real-time IOC and systemd Konrad, Martin via Tech-talk
Re: Real-time IOC and systemd Konrad, Martin via Tech-talk
Prev: Re: PyDM setting alarm with PVView example Hugo Slepicka via Tech-talk
Next: Re: write to a single element of an array field Benjamin Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: Real-time IOC and systemd Konrad, Martin via Tech-talk
Next: Re: Real-time IOC and systemd Konrad, Martin via Tech-talk
ANJ, 20 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
