Subject: Re: write to a single element of an array field
From: Benjamin Franksen via Tech-talk <[email protected]>
To: "Mooney, Tim M." <[email protected]>, EPICS Techtalk <[email protected]>
Date: Fri, 13 Mar 2020 21:29:11 +0100
Am 06.03.20 um 19:58 schrieb Mooney, Tim M.:
> Well, since no solution has been proposed, I'll give you my awkward
> and inefficient solution that will, nevertheless, work in a pinch.
> The following calc expression will make an acalcout record replace
> the element of array AA, whose index is in the A field, with the
> value in the B field:
> cat(cat(aa[0,a-1],b),aa[a+1,-1])
Fascinating!
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: write to a single element of an array field Mooney, Tim M. via Tech-talk
Prev: Re: Real-time IOC and systemd Benjamin Franksen via Tech-talk
Next: Re: write to a single element of an array field Ben Franksen via Tech-talk
Prev: Re: write to a single element of an array field Mooney, Tim M. via Tech-talk
Next: unable to parse json response when starting Eiger IOC Jong Woo Kim via Tech-talk
