Subject: Re: monitors on array variables
To: Michael Davidsaver <[email protected]>, "Siddons, David" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 18 Mar 2020 17:45:38 +0000
> db_post_events() must be called with whatever address is in DBADDR::pfield
> which by default in this case is '&val' but this can be changed in the
> cvt_dbaddr callback.  Indeed waveformRecord used to do this.
This is cvt_dbaddr from mcaRecord.c.  Note that it sets paddr->pfield to bptr if the fieldIndex is VAL.
static long cvt_dbaddr(struct dbAddr *paddr)
    mcaRecord *pmca=(mcaRecord *)paddr->precord;
    int fieldIndex = dbGetFieldIndex(paddr);
    if (fieldIndex == mcaRecordVAL) {
        paddr->pfield = (void *)(pmca->bptr);
    } else if (fieldIndex == mcaRecordBG) {
        paddr->pfield = (void *)(pmca->pbg);
    paddr->no_elements = pmca->nmax;
    paddr->field_type = pmca->ftvl;
    if (pmca->ftvl==0)  paddr->field_size = MAX_STRING_SIZE;
    else paddr->field_size = sizeofTypes[pmca->ftvl];
    paddr->dbr_field_type = pmca->ftvl;
    return(0);
Pete, what does your cvt_dbaddr look like?
Sent: Wednesday, March 18, 2020 11:54 AM
To: Mark Rivers; Siddons, David
Cc: EPICS Tech-Talk
On 3/18/20 9:47 AM, Mark Rivers wrote:
>> by analogy waveformRecord has
>>> db_post_events(prec, &prec->val, monitor_mask);
>> note 'val' not 'bptr'.
> The mca record has worked with no changes in 3.14, 3.15, and 7.0.3 with these lines:
> mcaRecord.dbd:
> recordtype(mca) {
>         include "dbCommon.dbd"
>         field(VERS,DBF_DOUBLE) {
>                 prompt("Code Version")
>                 special(SPC_NOMOD)
>                 initial("1")
>         field(VAL,DBF_NOACCESS) {
>                 prompt("Value")
>                 special(SPC_DBADDR)
>                 pp(TRUE)
>                 size(4)
>                 extra("void *val")
>         field(BPTR,DBF_NOACCESS) {
>                 prompt("Buffer Pointer")
>                 special(SPC_NOMOD)
>                 interest(4)
>                 size(4)
>                 extra("void *bptr")
> mcaRecord.c:
>     if (MARKED(M_VAL)) db_post_events(pmca,pmca->bptr,monitor_mask);
> So it is posting monitors on the bptr field, not the val field, and it seems to work fine.
> It looks like Pete is doing what the mca record does, but it is not working.  Why?
Ah, there is a second piece to the puzzle.
https://github.com/epics-base/epics-base/commit/92d52cc415599b7dffa7df1f23d5ba8227fb4d3a
monitors on array variables Siddons, David via Tech-talk
Re: monitors on array variables Michael Davidsaver via Tech-talk
Prev: Re: monitors on array variables Michael Davidsaver via Tech-talk
Next: Re: monitors on array variables Siddons, David via Tech-talk
