1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: monitors on array variables
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Siddons, David" <siddons at bnl.gov>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Wed, 18 Mar 2020 15:25:02 -0700
FYI. passing NULL instead of a field address to db_post_events()
will post to every subscription on the record regardless of field.
Trying this should give a clear indication if the only problem is
the wrong field address.
I guess the other variable is event mask.  SO
> db_post_events(pscal,NULL,0xf);
should post to every subscriber to this record regardless of field or mask.
On 3/18/20 12:02 PM, Mark Rivers wrote:
> Could this be a problem with EPICS_CA_MAX_ARRAY_BYTES?  What if you do:
> camonitor -#20  det1.SPCT
> ________________________________
> From: Siddons, David <siddons at bnl.gov>
> Sent: Wednesday, March 18, 2020 1:51 PM
> To: Mark Rivers; Michael Davidsaver
> Cc: EPICS Tech-Talk
> Hi Mark,
> Yes, I did that. THis is essentially an expanded scaler record. In updateCounts I have:
>         Debug(5, "updateCounts: posting scaler values %d\n",0);
>         /* copy and post spectrum values */
>         for (i=0; i<4096; i++) {
>                 if (mca[4096*pscal->monch+i] != spct[i]) {
>                       spct[i]=mca[4096*pscal->monch+i];
>          db_post_events(pscal,&pscal->mca,DBE_VALUE);
>          db_post_events(pscal,&pscal->tdc,DBE_VALUE);
>          db_post_events(pscal,&pscal->spct,DBE_VALUE);
> etc,
> It gives this output:
> ../zDDMRecord.c(818):updateCounts:   called by process()
> ../zDDMRecord.c(830):updateCounts: got counts[] 0
> ../zDDMRecord.c(838):updateCounts: posting scaler values 0
> ../zDDMRecord.c(866):updateCounts: exit 0
> Running camonitor on det1.SPCT reads the initial values and waits. Triggering a change (by changing monch) results in nothing. It just sits there. I can verify that the values have changed by doing a caget, or a dbgf on the console:
> peter@peter-Latitude-E7240: ~/$ caput det1.MONCH 0
> Old : det1.MONCH                     5
> New : det1.MONCH                     0
> peter@peter-Latitude-E7240: ~/$ caget det1.SPCT[1:20]
> det1.SPCT[1:20] 20 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
> peter@peter-Latitude-E7240: ~/$ caput det1.MONCH 5
> Old : det1.MONCH                     0
> New : det1.MONCH                     5
> peter@peter-Latitude-E7240:~/$ caget det1.SPCT[1:20]
> det1.SPCT[1:20] 20 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 100
> I guess I'm doing something dumb, but I can't see it.
> Pete.
> From: Mark Rivers <rivers at cars.uchicago.edu>
> Sent: Wednesday, March 18, 2020 2:25 PM
> To: Siddons, David <siddons at bnl.gov>; Michael Davidsaver <mdavidsaver at gmail.com>
> Can you put some debugging to be sure db_post_events is actually being called, while at the same time running camonitor to see if gets an update?
> Sent: Wednesday, March 18, 2020 1:09 PM
> To: Michael Davidsaver; Mark Rivers
> Cc: EPICS Tech-Talk
> .....and I have, in cvt_dbaddr():
>   case zDDMRecordSPCT:{
>       paddr->pfield = (void *)(pzDDM->pspct);
>       paddr->no_elements = 4096; /* One spectrum for real-time display */
>       paddr->field_type = DBF_LONG;
>       paddr->field_size = sizeof(int);
>       paddr->dbr_field_type = DBR_LONG;
>       break;
> Pete.
> From: Michael Davidsaver <mdavidsaver at gmail.com>
> Sent: Wednesday, March 18, 2020 12:54 PM
> To: Mark Rivers <rivers at cars.uchicago.edu>; Siddons, David <siddons at bnl.gov>
> On 3/18/20 9:47 AM, Mark Rivers wrote:
>>> by analogy waveformRecord has
>>>> db_post_events(prec, &prec->val, monitor_mask);
>>> note 'val' not 'bptr'.
>> The mca record has worked with no changes in 3.14, 3.15, and 7.0.3 with these lines:
>> mcaRecord.dbd:
>> recordtype(mca) {
>>         include "dbCommon.dbd"
>>         field(VERS,DBF_DOUBLE) {
>>                 prompt("Code Version")
>>                 special(SPC_NOMOD)
>>                 initial("1")
>>         field(VAL,DBF_NOACCESS) {
>>                 prompt("Value")
>>                 special(SPC_DBADDR)
>>                 pp(TRUE)
>>                 size(4)
>>                 extra("void *val")
>>         field(BPTR,DBF_NOACCESS) {
>>                 prompt("Buffer Pointer")
>>                 special(SPC_NOMOD)
>>                 interest(4)
>>                 size(4)
>>                 extra("void *bptr")
>> mcaRecord.c:
>>     if (MARKED(M_VAL)) db_post_events(pmca,pmca->bptr,monitor_mask);
>> So it is posting monitors on the bptr field, not the val field, and it seems to work fine.
>> It looks like Pete is doing what the mca record does, but it is not working.  Why?
> Ah, there is a second piece to the puzzle.
> db_post_events() must be called with whatever address is in DBADDR::pfield
> which by default in this case is '&val' but this can be changed in the
> cvt_dbaddr callback.  Indeed waveformRecord used to do this.
> https://github.com/epics-base/epics-base/commit/92d52cc415599b7dffa7df1f23d5ba8227fb4d3a
Re: monitors on array variables D. Peter Siddons via Tech-talk
monitors on array variables Siddons, David via Tech-talk
Re: monitors on array variables Michael Davidsaver via Tech-talk
Re: monitors on array variables Siddons, David via Tech-talk
Re: monitors on array variables Mark Rivers via Tech-talk
Prev: Re: monitors on array variables Siddons, David via Tech-talk
Next: error calling dbGetLinkValue in EPICS base-3.15.6 Anindya Roy via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Next: Re: monitors on array variables D. Peter Siddons via Tech-talk
ANJ, 19 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
