Subject: Re: Setting an array to zero length
From: Ben Franksen via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 3 Apr 2020 17:28:20 +0200
Am 03.04.20 um 16:25 schrieb Ralph Lange via Tech-talk:
> On Fri, 3 Apr 2020 at 15:04, Ben Franksen via Tech-talk <
> [email protected]> wrote:
> You could also try to use another
>> record with NELM=NORD=0 and that has an output link that you point to
>> your WAVE record. There is no record type in base with such an output
>> link [...]
> The aaoRecord since Base 3.12.2 (ca. 1995)
Thanks I completely forgot about this one. Indeed this works:
record(waveform, "wf") {
    field(NELM, "10")
    field(FTVL, "DOUBLE")
    field(INP, [1, 2, 3, 4, 5, 6, 7, 8])
    field(PINI, "YES")
record(aao, "reset") {
    field(NELM, "0")
    field(OUT, "wf PP")
ben@juliana[1]:.../base/7.0>caget wf
wf 10 1 2 3 4 5 6 7 8 0 0
ben@juliana[1]:.../base/7.0>caget wf.NORD
wf.NORD                        8
ben@juliana[1]:.../base/7.0>caput reset.PROC 1
Old : reset.PROC                     0
New : reset.PROC                     1
wf.NORD                        0
wf 10 2.50321e-308 0 0 0 0 0 0 0 0 0
The last response is unexpected though. While caget -h indeed says:
Arrays: Value format: print number of requested values, then list of values
printing the actual number of values in the response (and only so many
values) would be more useful. Does CA not return the current number of
values in an array?
Cheers
Ben
...it is impossible to speak of a depoliticized economy as the liberals
do, or of a separation between economic exploitation and political
oppression as the Marxists articulate. The basic distinction, rather, is
between power and creativity...
             -- Jonathan Nitzan and Shimshon Bichler: Capital as Power
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Setting an array to zero length Ben Franksen via Tech-talk
Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
Re: Setting an array to zero length Ralph Lange via Tech-talk
Prev: RE: Packages to build EPICS base, synApps, and areaDetector on Centos 8 Mark Rivers via Tech-talk
Next: Re: Packages to build EPICS base, synApps, and areaDetector on Centos 8 J. Lewis Muir via Tech-talk
Prev: Re: Setting an array to zero length Ralph Lange via Tech-talk
Next: Re: Setting an array to zero length Ben Franksen via Tech-talk
