Subject: Re: Setting an array to zero length
From: Ben Franksen via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 3 Apr 2020 17:43:37 +0200
Am 03.04.20 um 17:28 schrieb Ben Franksen via Tech-talk:
> Am 03.04.20 um 16:25 schrieb Ralph Lange via Tech-talk:
>> On Fri, 3 Apr 2020 at 15:04, Ben Franksen via Tech-talk <
>> [email protected]> wrote:
>> You could also try to use another
>>> record with NELM=NORD=0 and that has an output link that you point to
>>> your WAVE record. There is no record type in base with such an output
>>> link [...]
>> The aaoRecord since Base 3.12.2 (ca. 1995)
> Thanks I completely forgot about this one. Indeed this works:
> record(waveform, "wf") {
>     field(NELM, "10")
>     field(FTVL, "DOUBLE")
>     field(INP, [1, 2, 3, 4, 5, 6, 7, 8])
>     field(PINI, "YES")
> record(aao, "reset") {
>     field(NELM, "0")
>     field(OUT, "wf PP")
> ben@juliana[1]:.../base/7.0>caget wf
> wf 10 1 2 3 4 5 6 7 8 0 0
> ben@juliana[1]:.../base/7.0>caget wf.NORD
> wf.NORD                        8
> ben@juliana[1]:.../base/7.0>caput reset.PROC 1
> Old : reset.PROC                     0
> New : reset.PROC                     1
> wf.NORD                        0
> wf 10 2.50321e-308 0 0 0 0 0 0 0 0 0
> The last response is unexpected though. While caget -h indeed says:
> Arrays: Value format: print number of requested values, then list of values
> printing the actual number of values in the response (and only so many
> values) would be more useful. Does CA not return the current number of
> values in an array?
Ah, I see. This is a limitation of the simple ca_array_get call which is
used by default. It works as expected if I pass the -c option which
makes it use ca_array_get_callback which can return the current number
of elements.
Cheers
Ben
...it is impossible to speak of a depoliticized economy as the liberals
do, or of a separation between economic exploitation and political
oppression as the Marxists articulate. The basic distinction, rather, is
between power and creativity...
             -- Jonathan Nitzan and Shimshon Bichler: Capital as Power
Attachment: signature.asc
Description: OpenPGP digital signature
Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
Re: Setting an array to zero length Ben Franksen via Tech-talk
Re: Setting an array to zero length Ralph Lange via Tech-talk
Prev: Re: Packages to build EPICS base, synApps, and areaDetector on Centos 8 J. Lewis Muir via Tech-talk
Next: Re: EDM in RHEL8 or Centos8 Ernesto Paiser via Tech-talk
Prev: Re: Setting an array to zero length Ben Franksen via Tech-talk
Next: Re: Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
