Subject: Re: EDM in RHEL8 or Centos8
From: Ernesto Paiser via Tech-talk <[email protected]>
To: "Williams Jr., Ernest L." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Apr 2020 08:46:07 -0700
Hi Ernest,
I'm doing well. Regardless someone here may have got the covid...
Hope you are as well as, safe and healthy!
This message you got is because the gif.cc should check the giflib version and set the #define accordingly, but isn't working.
giflib has changed the definition for the functions:
DGifCloseFile and DGifOpenFileName
since version 5 adding an additional parameter *errno for the arguments.
If you force to compile with giflib version 5.1 you'll  get rid of this
error, but you may found others like me.
To make a test just modify gif.cc as:
//#if GIFLIB_MAJOR > 5 || GIFLIB_MAJOR == 5 && GIFLIB_MINOR >= 1
  #define GIF_CLOSE_FILE(gif) DGifCloseFile(gif, NULL)
  #define GIF_OPEN_FILE(gif) DGifOpenFileName(gif, NULL)
//#else
//  #define GIF_CLOSE_FILE(gif) DGifCloseFile(gif)
//  #define GIF_OPEN_FILE(gif) DGifOpenFileName(gif)
//#endif
and compile again.
Let me know if you make some progress, Thanks
 Ernesto
On 4/3/20 7:49 AM, Williams Jr., Ernest L. wrote:
Hi Ernesto,
How is it going?
Our production systems are using mainly RHEL6 and RHEL7.
I have started looking ahead to RHEL 8.
What version of EDM are you using there?
Please provide more detail:
 1. Version of EPICS
 2. Version of EDM
 3. Version of giflib
Here is what I have on my centos8 box:
OS = CentOS Linux release 8.1.1911 (Core)
EPICS BASE = 7.0.3.1
EDM = 1.12.105B
GIFLIB = giflib-devel-5.1.4-3.el8.x86_64
Looks like we have a problem.
Here is my error message:
make -C ./giflib install
make[1]: Entering directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
     T_A=linux-x86_64 install
make[2]: Entering directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib/O.linux-x86_64' /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -std=c++98 -fpermissive -Wno-write-strings -DNO_UNORDERED_MAP -DSINGLE_THREADED=1 -D__epics__=1  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include  -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include/compiler/gcc -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include/os/Linux -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include -I../../util -I../../edmlib -I/usr/include -I/usr/include/X11    -c ../gif.cc ../gif.cc: In constructor ‘activeGifClass::activeGifClass(const activeGifClass*)’: ../gif.cc:245:5: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
  int status;
../gif.cc: In member function ‘int activeGifClass::readGifFile()’:
../gif.cc:24:50: error: too few arguments to function ‘GifFileType* DGifOpenFileName(const char*, int*)’
../gif.cc:442:11: note: in expansion of macro ‘GIF_OPEN_FILE’
      gif = GIF_OPEN_FILE( name );
In file included from ../gif.h:28,
                  from ../gif.cc:39:
/usr/include/gif_lib.h:179:14: note: declared here
  GifFileType *DGifOpenFileName(const char *GifFileName, int *Error);
../gif.cc:23:48: error: too few arguments to function ‘int DGifCloseFile(GifFileType*, int*)’
../gif.cc:898:12: note: in expansion of macro ‘GIF_CLOSE_FILE’
    status = GIF_CLOSE_FILE( gif );
                  from ../gif.cc:39:
/usr/include/gif_lib.h:183:9: note: declared here
      int DGifCloseFile(GifFileType * GifFile, int *ErrorCode);
../gif.cc:910:30: note: in expansion of macro ‘GIF_CLOSE_FILE’
    if ( fileOpened ) status = GIF_CLOSE_FILE( gif );
                  from ../gif.cc:39:
make[2]: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_BUILD:251: gif.o] Error 1 make[2]: Leaving directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib/O.linux-x86_64' make[1]: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 make[1]: Leaving directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib' make: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_DIRS:84: giflib.install] Error 2'
Cheers,
Ernesto
Re: EDM in RHEL8 or Centos8 Williams Jr., Ernest L. via Tech-talk
EDM in RHEL8 or Centos8 Ernesto Paiser via Tech-talk
Prev: Re: Setting an array to zero length Ben Franksen via Tech-talk
Next: Re: EDM in RHEL8 or Centos8 Williams Jr., Ernest L. via Tech-talk
Prev: Re: EDM in RHEL8 or Centos8 Williams Jr., Ernest L. via Tech-talk
