Subject: RE: Newport DL325
To: 'Igor Kriznar' <[email protected]>
Date: Wed, 8 Apr 2020 16:08:35 +0000
> Is there any existing support for ThorLab BBD201 controller?
I don't know of any, but perhaps others on tech-talk may.
-----Original Message-----
Sent: Wednesday, April 8, 2020 10:51 AM
Subject: Re: Newport DL325
Hi Mark,
thanks, so far so good.
Next motor controller on my list to support is ThorLabs BBD201 (for
DDS300 Translation Stage).
I can see there is the motorThorLabs driver and document states support for Piezo Controller, Model MDT695.
I have found communication specifications for BBD201:
https://www.thorlabs.com/software_pages/ViewSoftwarePage.cfm?Code=Motion_Control
But I can not find MDT695 anywhere. Closest thing seems to be MDT694B:
https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=1191&pn=MDT694B
Checking communication specs shows, that it is a very different protocol.
Thanks and best regards, Igor
On 07.04.20 17:02, Mark Rivers wrote:
> Hi Igor,
> If you go to motorNewport/iocs and type "make" it will build a sample IOC.  Then go to iocs/newportIOC/iocBoot/iocNewport and edit one of the example st.cmd.* files and motors.substitutions.* files.  Then you should be able to test your driver.
> Mark
> ________________________________
> From: Igor Kriznar <[email protected]>
> Sent: Tuesday, April 7, 2020 9:48 AM
> To: Mark Rivers
> Hi Mark,
> I did exactly what you suggested. Pretty trivial as you said.
> In cpp file line 180 I have added some initialization. Although that
> fields are used only in report method, so might be used as local
> variables there.
> In cpp file line 532, it seems that limits will never be 1.
> I still need to test the code on my device.
> Would you happen to have a sample IOC at hand, it would help me with
> configuration?
> Thanks for your help,
> Best regards, Igor
> On 01.04.20 14:35, Mark Rivers wrote:
>>> I see some overlap in commands with CONEX controller
>> (https://www.newport.com/mam/celum/celum_assets/resources/CONEX-CC_-_Command_Interface_Manual.pdf?1).
>> That is not the correct manual for the CONEX to compare.  That
>> describes the DLL interface.  You just want the ASCII command
>> interface which is this manual:
>> ontroller_Documentation.pdf?1
>>> For second, the command interface for DL controller
>> (https://www.newport.com/mam/celum/celum_assets/resources/DL_Controll
>> er_-_Command_Interface_Manual.pdf?1)
>>> has about 200 commands.
>> I see only 64 commands, of which the driver needs to support only a small fraction.
>> These are the command that are actually used in the CONEX driver that appear to be identical in the DL driver:
>> Read controller version: "VE"
>> Read stage type: "ID"
>> Home: "OR"
>> Move absolute: "PA"
>> Acceleration: "AC"
>> Velocity: "VA"
>> Move relative: "PR"
>> Move absolute: "PA"
>> Stop: "ST"
>> Reset controller: "RS"
>> Read current position:  "TP"
>> Read status: "TS"
>> Software limits: "SL" and "SR"
>> PID parameters: "KP", "KI", "KD"
>> Closed loop: "MM"
>> These are the commands that the CONEX driver uses that the DL does not support:
>> Read encoder increment: "SU"
>> Read interpolation factor: "IF"
>> Read microsteps: "FRM"
>> Read full step size: "FRS"
>> Home type: "HT"
>> However, those commands are all done within conditional statements depending on the controller type like this:
>>     // Read the encoder increment (CC and AGP only)
>>     if ((conexModel_ == ModelConexAGP) || (conexModel_ == ModelConexCC)) {
>>       sprintf(pC_->outString_, "%dSU?", pC->controllerID_);
>>       pC_->writeReadController();
>>       encoderIncrement_ = atof(&pC_->inString_[3]);
>>     } else {
>>       encoderIncrement_ = 1.;
>> I am now convinced that modifying the AG_CONEX.cpp driver to also support the DL controller is pretty trivial.
>> The CONEX driver currently supports 3 models:
>> typedef enum {
>>     ModelConexAGP,
>>     ModelConexCC,
>>     ModelConexPP
>> } ConexModel_t;
>> All you need to do is add a ModelDL to the above list and change a few conditionals so that the driver never sends unsupported commands for the DL model.
>> Mark
>> Sent: Wednesday, April 1, 2020 5:22 AM
>> To: Mark Rivers
>> Hi Mark,
>> thanks for the tip.
>> my plan was to check, if motor record supports my device. And if not,
>> to implement that few commands that will be actually used trough StreamDevice.
>> For first, I have no experience with motor record development. For
>> I see utility in having motor record, but I am not sure how much more
>> effort the driver will it take in comparison to StreamDevice. I see
>> If you have any advice on this, I would appreciate .
>> Stay well,
>> Igor
>> On 31.03.20 20:01, Mark Rivers wrote:
>>> Hi Igor,
>>> It looks like they are only supporting the DL Single-Axis Motion Controller for those stages.
>>> The User Manual documents the command syntax:
>>> https://www.newport.com/mam/celum/celum_assets/resources/DL_-_Contro
>>> ller_Users_Manual.pdf?1
>>> The command syntax is very similar to the Newport AG_CONEX controllers, for which there is an EPICS driver.
>>> https://github.com/epics-motor/motorNewport/blob/master/newportApp/s
>>> rc/AG_CONEX.cpp
>>> You may be able to use the AG_CONEX driver, or you may have to write a new driver starting with that one but modifying the commands and syntax a bit.
>>> Mark
>>> From: Tech-talk <[email protected]> on behalf of Igor
>>> Kriznar via Tech-talk <[email protected]>
>>> Sent: Tuesday, March 31, 2020 8:27 AM
>>> To: [email protected]
>>> Subject: Newport DL325
>>> Hi,
>>> is motor record working with Newport DL325 (a Delay Line Stage) with
>>> DL Controller?
>>> Thanks!
>>> Best regards, Igor
Newport DL325 Igor Kriznar via Tech-talk
Re: Newport DL325 Mark Rivers via Tech-talk
Re: Newport DL325 Igor Kriznar via Tech-talk
Prev: Re: Newport DL325 Igor Kriznar via Tech-talk
Next: Re: Setting an array to zero length Johnson, Andrew N. via Tech-talk
Next: ThorLabs BBD201 Igor Kriznar via Tech-talk
