Subject: Re: Setting an array to zero length
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Kay Kasemir <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 8 Apr 2020 19:29:01 +0000
I expected the PVA protocol to be able to handle zero-length arrays, thanks for confirming that. My main question is what happens if QSRV tries to put one into a waveform record or other array field, since it’s calling the IOC to actually write the value and length. From a brief look at some parts of the IOC code it might work, but I would want someone to try it to be sure. Make sure the record already has at least one element in it before testing that...
- Andrew
On Apr 8, 2020, at 2:20 PM, Kasemir, Kay <[email protected]> wrote:
> It is not currently (and may never be) possible to put a zero-length array through Channel Access;
> I don’t know if PVA and QSRV can handle them or not.
For PVAccess, the protocol has different type identifiers for scalars and arrays, so a 'double' is  clearly distinguished from a 'double []' with exactly one element.
When using an array type, the length can change at runtime and include zero length == empty array.
As for QSRV, when you create a 'compress' record with NSAM = 1, the PV is a an NTScalar. For NSAM > 1 the PV is of type NTScalarArray.
So it behaves just like the Channel Access example, an array of size 1 appears as a scalar.
Not sure if this is a quirk in QSRV that could be fixed, or if the limitation is in the database/IOC API that it needs to use.
-Kay
Complexity comes for free, simplicity you have to work for.
Re: Setting an array to zero length Michael Davidsaver via Tech-talk
Re: Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
Re: Setting an array to zero length Johnson, Andrew N. via Tech-talk
Re: Setting an array to zero length Kasemir, Kay via Tech-talk
Prev: Re: Setting an array to zero length Kasemir, Kay via Tech-talk
Next: Re: Setting an array to zero length Michael Davidsaver via Tech-talk
