Subject: Re: Setting an array to zero length
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, Kay Kasemir <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 8 Apr 2020 13:19:08 -0700
With QSRV a database field is mapped as a PVA "scalar" when dbChannelFinalElements()==1 .
QSRV allows writing zero length arrays.
> pvput wf value=[1]
> Old : 2020-04-08 13:15:58.618  []
> New : 2020-04-08 13:17:43.011  [1]
> pvput wf value=[]
> Old : 2020-04-08 13:17:43.011  [1]
> New : 2020-04-08 13:17:44.250  []
'wf' is a waveformRecord.
On 4/8/20 12:29 PM, Johnson, Andrew N. via Tech-talk wrote:
> I expected the PVA protocol to be able to handle zero-length arrays, thanks for confirming that. My main question is what happens if QSRV tries to put one into a waveform record or other array field, since it’s calling the IOC to actually write the value and length. From a brief look at some parts of the IOC code it might work, but I would want someone to try it to be sure. Make sure the record already has at least one element in it before testing that...
> - Andrew
>> On Apr 8, 2020, at 2:20 PM, Kasemir, Kay <[email protected] <mailto:[email protected]>> wrote:
>> > It is not currently (and may never be) possible to put a zero-length array through Channel Access;
>> > I don’t know if PVA and QSRV can handle them or not.
>> For PVAccess, the protocol has different type identifiers for scalars and arrays, so a 'double' is  clearly distinguished from a 'double []' with exactly one element.
>> When using an array type, the length can change at runtime and include zero length == empty array.
>> As for QSRV, when you create a 'compress' record with NSAM = 1, the PV is a an NTScalar. For NSAM > 1 the PV is of type NTScalarArray.
>> So it behaves just like the Channel Access example, an array of size 1 appears as a scalar.
>> Not sure if this is a quirk in QSRV that could be fixed, or if the limitation is in the database/IOC API that it needs to use.
>> -Kay
> Complexity comes for free, simplicity you have to work for.
Re: Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
Re: Setting an array to zero length Johnson, Andrew N. via Tech-talk
Re: Setting an array to zero length Kasemir, Kay via Tech-talk
Prev: Re: Setting an array to zero length Johnson, Andrew N. via Tech-talk
Next: Re: Setting an array to zero length Michael Davidsaver via Tech-talk
