Subject: Re: Home motorSim Device
To: William Cork <[email protected]>
Date: Fri, 10 Apr 2020 16:44:22 +0000
Hi Will,
I don't know the state of Kunal's repository that you referenced.  I think the more "official" simulated motor repository is this one:
https://github.com/epics-motor/motorMotorSim
There are actually 2 drivers in that source code, a "Model 2" driver (drvMotorSim.c) and a new "Model 3" driver (motorSimDriver.cpp).  I recommend only using motorSimDriver.cpp since that is the current standard framework.
The example IOC loads 8 motors.  The first 4 are the old Model 2 driver, and the last 4 are the new Model 3 driver.
I just tested homing with both drivers.
With the Model 2 driver when the homing is complete MSTA is 0xa.  This is bits 1 and 3 which mean
        unsigned int RA_HOME        :1; /* The home signal is on */
        unsigned int RA_DONE        :1; /* a motion is complete */
With the Model 3 driver when the homing is complete the MSTA is 0x82.  This is bits 1 and 7 which mean
        unsigned int EA_HOME        :1; /* encoder home signal on */
So one driver sets RA_HOME (not encoder home) while the other set EA_HOME (encoder home).
Note that neither of them set bit 14 which is
  unsigned int RA_HOMED       :1; /* Axis has been homed.*/
This is probably an bug in these drivers, they should be setting that bit as well.
From: Tech-talk <[email protected]> on behalf of William Cork via Tech-talk <[email protected]>
Sent: Friday, April 10, 2020 10:25 AM
To: [email protected]
Subject: Home motorSim Device
Playing around with the motor and asyn modules to get more familiar with EPICS motion control.
I'm using an example motorSim found here: https://github.com/shroffk/motorsim.git
Using:
asyn-R4-37
motor-R7-1
calc-R3-7-3
Having an issue where I tell an sioc using motorSim to home but, the MSTA record never updates the HOMED bit.
Startup deck has these lines to configure motorSim device:
motorSimCreate( 0, 0, -32000, 32000, 0, 1, 6 )
drvAsynMotorConfigure("motorSim1", "motorSim", 0, 6)
fakemotor.db:
record(ao, "$(Sys)$(Dev)-SP") {
    field(FLNK, "$(Sys)$(Dev)-SP_")
record(seq, "$(Sys)$(Dev)-SP_") {
    #disable mtr rec processing
    field(DOL1, "1")
    field(LNK1, "$(Mtr).DISA")
    # write setpoint to mtr rec
    field(DLY2, "0.1")
    field(DOL2, "$(Sys)$(Dev)-SP")
    field(LNK2, "$(Mtr).VAL CP")
    # to re-enable mtr rec processing, write or process "$(Sys)$(Dev)Cmd:Go-Cmd"
record(ai, "$(Sys)$(Dev)-I") {
    field(INP, "$(Mtr).RBV CPP")
record(bo, "$(Sys)$(Dev)Cmd:Go-Cmd") {
    field(DOL, "0")
    field(OUT, "$(Mtr).DISA CPP")
record(bo, "$(Sys)$(Dev)Cmd:Stop-Cmd") {
    field(VAL, "1")
    field(OUT, "$(Mtr).STOP CPP")
record(bi, "$(Sys)$(Dev)Sts:Moving-Sts") {
    field(INP, "$(Mtr).DMOV CPP")
    field(ZNAM, "Moving")
    field(ONAM, "Done")
Does motorSim have support for homing?
Is it broken from the seq record in fakemotor.db?
Your help is appreciated,
Will
Re: Home motorSim Device William Cork via Tech-talk
Re: Home motorSim Device Peterson, Kevin M. via Tech-talk
Prev: Home motorSim Device William Cork via Tech-talk
Next: RE: Filtering messages print on the IOC shell console Freddie Akeroyd - UKRI STFC via Tech-talk
Next: Re: Home motorSim Device William Cork via Tech-talk
