Subject: Re: enable PV searching only over TCP
From: Michael Davidsaver via Tech-talk <[email protected]>
To: 黄佳伟 <[email protected]>
Date: Mon, 13 Apr 2020 00:39:37 -0700
On 4/12/20 11:58 PM, 黄佳伟 via Tech-talk wrote:
> Hi,
>     I'm working on EPICS clients located in a specialized network, where UDP streaming is blocked, so conventional UDP searching message cannot be sent and received. I heard that these messages can be sent over TCP after a certain version of EPICS. So how can i enable this feature?
export EPICS_CA_NAME_SERVERS=...
export EPICS_CA_AUTO_ADDR_LIST=NO
The name servers list should contain the IP:port (tcp port) of _all_ CA servers
which the client needs to reach.  Typically, this is a CA gateway, so the list
isn't too large.  Directly searching to more than a few IOCs this way will quickly
become unwieldy.
enable PV searching only over TCP 黄佳伟 via Tech-talk
Prev: enable PV searching only over TCP 黄佳伟 via Tech-talk
Next: Galil device support - static build John Dobbins via Tech-talk
