Subject: Re: Filtering messages print on the IOC shell console
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 13 Apr 2020 09:48:48 -0500
On 04/10, Johnson, Andrew N. wrote:
> Users of previous Base releases can fix the problem (which I believe should only ever occur on IOCs running on VxWorks or RTEMS with GeSys, never on any of the targets such as Linux or Windows that use the iocsh) by adding the call like Mark did, just after the IOC’s munch file or core binary has been loaded:
> I added the following at the top of my startup script:
> epicsThreadSetOkToBlock(1)
> value = 0 = 0x0
> Indeed that fixes the problem!
> Thanks to everyone who contributed ideas!
Thanks!  That workaround works for me too!
Lewis
Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
Re: Filtering messages print on the IOC shell console Mark Rivers via Tech-talk
Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
RE: Filtering messages print on the IOC shell console Mark Rivers via Tech-talk
Prev: Galil device support - static build John Dobbins via Tech-talk
Next: Re: Galil device support - static build Mooney, Tim M. via Tech-talk
Prev: Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
Next: Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
