Subject: Re: Galil device support - static build
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, John Dobbins <[email protected]>
Date: Mon, 13 Apr 2020 16:03:32 +0000
We found that a systematic way to avoid link problems like this is to list them in opposing order:
$(DBD_NAME)_DBD
 += stdSupport.dbd
$(PROD_NAME)_LIBS := std $($(PROD_NAME)_LIBS)
For DBD files, a name must be defined before it is referenced.  For LIB files, a name must be referenced before the library containing it is searched.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Monday, April 13, 2020 9:31 AM
To: [email protected] <[email protected]>
Subject: Galil device support - static build
All,
Doing a static build of Galil 3-6 device support I ran into the problem described below. Solved by changing order of libraries.
John Dobbins
For static build of Galil 3-6
In galil/3-6/GalilTestApp/src
I changed Makefile from
GalilTest_LIBS += asyn motor calc sscan autosave busy
GalilTest_LIBS += GalilSupport
GalilTest_LIBS += $(EPICS_BASE_IOC_LIBS)
to
because of link error:
/usr/bin/g++ -o GalilTest -Wl,-Bstatic -L/nfs/chess/user/jad22/epics/support/galil/3-6/lib/linux-x86_64 -L/nfs/chess/epics/release/base/base-7.0.2/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/asyn-R4-38/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/autosave-R5-10/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/busy-R1-7-2/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/calc-R3-7-3/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/motor-R7-1/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/sscan-R2-11-3/lib/linux-x86_64            -rdynamic -m64 GalilTest_registerRecordDeviceDriver.o GalilTestMain.o -lasyn -lmotor -lcalc -lsscan -lautosave -lbusy -lGalilSupport -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lpthread -lreadline -lm -lrt -ldl -lgcc
/nfs/chess/user/jad22/epics/support/galil/3-6/lib/linux-x86_64/libGalilSupport.a(GalilController.o): In function `GalilCreateAxis':
/nfs/chess/user/jad22/epics/support/galil/3-6/GalilSup/src/O.linux-x86_64/../GalilController.cpp:7242: undefined reference to `findAsynPortDriver(char const*)'
[When you specify multiple inter-dependent static libraries via -l flag  dependents must go first, then their dependencies.]
Re: Galil device support - static build Ben Franksen via Tech-talk
Galil device support - static build John Dobbins via Tech-talk
Prev: Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
Next: Announcing PVXS Michael Davidsaver via Tech-talk
Prev: Galil device support - static build John Dobbins via Tech-talk
Next: Re: Galil device support - static build Ben Franksen via Tech-talk
